QI charging back cover
Has anyone solved the Qi charging back cover issue with the pro?
I think I have come up with an aftermarket battery expansion setup that could work great but the Pinephone Pro does not work with the Qi back cover. My Qi back cover works with my regular pinephone but will not charge with my Pro. I think its related to how far the pogo pins stick out on the Pro but I cant seem to confirm that.
Has anyone had any luck using the Qi back cover on the pro?
If I can get Qi charging working I believe I have a solution that a lot of people would be interested in to use the Pro as a daily since you either need working suspend or a huge battery to run it all day.
Thanks.
  Charging woes Barugon 2 1,013 05-26-2023, 10:23 PM
Last Post: Barugon
  Battery charging issue kileel 1 1,755 12-13-2021, 03:58 PM
Last Post: kileel
