OpenWrt support
I'm working on OpenWrt for the Quartz64, not working yet the SATA and HDMI ports, although they are not strictly necessary to use OpenWrt.
Current build is based on patches from Peter Geis , main line kernel 5.18 and uboot v22.07-rc2.
OpenWrt Quartz64 github source code:
https://github.com/mj22226/openwrt/commits/linux-5.18
Build images:
https://github.com/mj22226/openwrt/relea...kchip-5.18
nice, thank you for your work!
SATA should technically work on 5.18 if a) you build with the naneng combphy driver enabled, b) you disable the USB 3 port, c) you enable the sata1 controller
Since SATA is going away in the next hardware revision due to breaking USB 3, it's probably okay to leave it out though Smile
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
I have done iperf3 performance comparisons between 3 PCIe nic that I have, intel I350 x4, intel I225 x1 and RTL8125 x2 with the server on the PC:
root@OpenWrt:~# lspci
00:00.0 PCI bridge: Rockchip Electronics Co., Ltd RK3568 Remote Signal Processor (rev 01)
01:00.0 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
01:00.1 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
01:00.2 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
01:00.3 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
root@OpenWrt:~# iperf3 -c 192.168.1.223                      | root@OpenWrt:~# iperf3 -c 192.168.1.223 --bidir
Connecting to host 192.168.1.223, port 5201                    Connecting to host 192.168.1.223, port 5201
[  5] local 192.168.1.1 port 38794 connected to 192.168.1.223 | [  5] local 192.168.1.1 port 48362 connected to 192.168.1.223
[ ID] Interval          Transfer    Bitrate        Retr  C | [  7] local 192.168.1.1 port 48372 connected to 192.168.1.223
[  5]  0.00-1.00  sec  114 MBytes  958 Mbits/sec    0    | [ ID][Role] Interval          Transfer    Bitrate        R
[  5]  1.00-2.00  sec  111 MBytes  935 Mbits/sec    0    | [  5][TX-C]  0.00-1.00  sec  111 MBytes  932 Mbits/sec
[  5]  2.00-3.00  sec  112 MBytes  942 Mbits/sec    0    | [  7][RX-C]  0.00-1.00  sec  112 MBytes  936 Mbits/sec
[  5]  3.00-4.00  sec  112 MBytes  942 Mbits/sec    0    | [  5][TX-C]  1.00-2.00  sec  112 MBytes  944 Mbits/sec
[  5]  4.00-5.00  sec  112 MBytes  942 Mbits/sec    0    | [  7][RX-C]  1.00-2.00  sec  112 MBytes  938 Mbits/sec
[  5]  5.00-6.00  sec  112 MBytes  942 Mbits/sec    0    | [  5][TX-C]  2.00-3.00  sec  111 MBytes  933 Mbits/sec
[  5]  6.00-7.00  sec  112 MBytes  941 Mbits/sec    0    | [  7][RX-C]  2.00-3.00  sec  112 MBytes  937 Mbits/sec
[  5]  7.00-8.00  sec  112 MBytes  940 Mbits/sec    0    | [  5][TX-C]  3.00-4.00  sec  112 MBytes  943 Mbits/sec
[  5]  8.00-9.00  sec  112 MBytes  942 Mbits/sec    0    | [  7][RX-C]  3.00-4.00  sec  112 MBytes  938 Mbits/sec
[  5]  9.00-10.00  sec  112 MBytes  936 Mbits/sec    0    | [  5][TX-C]  4.00-5.00  sec  111 MBytes  933 Mbits/sec
                                                              > [  7][RX-C]  4.00-5.00  sec  112 MBytes  938 Mbits/sec
                                                              > [  5][TX-C]  5.00-6.00  sec  112 MBytes  943 Mbits/sec
                                                              > [  7][RX-C]  5.00-6.00  sec  112 MBytes  937 Mbits/sec
                                                              > [  5][TX-C]  6.00-7.00  sec  111 MBytes  933 Mbits/sec
                                                              > [  7][RX-C]  6.00-7.00  sec  112 MBytes  937 Mbits/sec
                                                              > [  5][TX-C]  7.00-8.00  sec  112 MBytes  943 Mbits/sec
                                                              > [  7][RX-C]  7.00-8.00  sec  112 MBytes  938 Mbits/sec
                                                              > [  5][TX-C]  8.00-9.00  sec  111 MBytes  933 Mbits/sec
                                                              > [  7][RX-C]  8.00-9.00  sec  112 MBytes  937 Mbits/sec
                                                              > [  5][TX-C]  9.00-10.00  sec  112 MBytes  943 Mbits/sec
                                                              > [  7][RX-C]  9.00-10.00  sec  112 MBytes  938 Mbits/sec
[ ID] Interval          Transfer    Bitrate        Retr    | [ ID][Role] Interval          Transfer    Bitrate        R
[  5]  0.00-10.00  sec  1.10 GBytes  942 Mbits/sec    0    | [  5][TX-C]  0.00-10.00  sec  1.09 GBytes  938 Mbits/sec
[  5]  0.00-10.00  sec  1.10 GBytes  941 Mbits/sec          | [  5][TX-C]  0.00-10.00  sec  1.09 GBytes  936 Mbits/sec
                                                              > [  7][RX-C]  0.00-10.00  sec  1.09 GBytes  940 Mbits/sec
                                                              > [  7][RX-C]  0.00-10.00  sec  1.09 GBytes  937 Mbits/sec
iperf Done.                                                    iperf Done.
Intel i225 x1
root@OpenWrt:~# lspci                                          root@OpenWrt:~# lspci
00:00.0 PCI bridge: Rockchip Electronics Co., Ltd RK3568 Remo  00:00.0 PCI bridge: Rockchip Electronics Co., Ltd RK3568 Remo
te Signal Processor (rev 01)                                    te Signal Processor (rev 01)
01:00.0 Ethernet controller: Intel Corporation Ethernet Contr  01:00.0 Ethernet controller: Intel Corporation Ethernet Contr
oller I225-LM (rev 03)                                          oller I225-LM (rev 03)
root@OpenWrt:~# iperf3 -c 192.168.1.218 -c 192.168.1.199      | root@OpenWrt:~# iperf3 -c 192.168.1.218 -c 192.168.1.199 --bi
Connecting to host 192.168.1.199, port 5201                    Connecting to host 192.168.1.199, port 5201
[  5] local 192.168.1.1 port 43784 connected to 192.168.1.199 | [  5] local 192.168.1.1 port 34584 connected to 192.168.1.199
[ ID] Interval          Transfer    Bitrate        Retr  C | [  7] local 192.168.1.1 port 34600 connected to 192.168.1.199
[  5]  0.00-1.00  sec  278 MBytes  2.33 Gbits/sec    0    | [ ID][Role] Interval          Transfer    Bitrate        R
[  5]  1.00-2.00  sec  280 MBytes  2.35 Gbits/sec    0    | [  5][TX-C]  0.00-1.00  sec  175 MBytes  1.47 Gbits/sec
[  5]  2.00-3.00  sec  281 MBytes  2.36 Gbits/sec    0    | [  7][RX-C]  0.00-1.00  sec  120 MBytes  1.01 Gbits/sec
[  5]  3.00-4.00  sec  280 MBytes  2.35 Gbits/sec    0    | [  5][TX-C]  1.00-2.00  sec  150 MBytes  1.26 Gbits/sec
[  5]  4.00-5.00  sec  280 MBytes  2.35 Gbits/sec    0    | [  7][RX-C]  1.00-2.00  sec  141 MBytes  1.18 Gbits/sec
[  5]  5.00-6.00  sec  281 MBytes  2.36 Gbits/sec    0    | [  5][TX-C]  2.00-3.00  sec  148 MBytes  1.24 Gbits/sec
[  5]  6.00-7.00  sec  280 MBytes  2.35 Gbits/sec    0    | [  7][RX-C]  2.00-3.00  sec  140 MBytes  1.17 Gbits/sec
[  5]  7.00-8.00  sec  281 MBytes  2.36 Gbits/sec    0    | [  5][TX-C]  3.00-4.00  sec  150 MBytes  1.26 Gbits/sec
[  5]  8.00-9.00  sec  280 MBytes  2.35 Gbits/sec    0    | [  7][RX-C]  3.00-4.00  sec  140 MBytes  1.18 Gbits/sec
[  5]  9.00-10.00  sec  281 MBytes  2.36 Gbits/sec    0    | [  5][TX-C]  4.00-5.00  sec  149 MBytes  1.25 Gbits/sec
                                                              > [  7][RX-C]  4.00-5.00  sec  141 MBytes  1.18 Gbits/sec
                                                              > [  5][TX-C]  5.00-6.00  sec  149 MBytes  1.25 Gbits/sec
                                                              > [  7][RX-C]  5.00-6.00  sec  139 MBytes  1.17 Gbits/sec
                                                              > [  5][TX-C]  6.00-7.00  sec  150 MBytes  1.26 Gbits/sec
                                                              > [  7][RX-C]  6.00-7.00  sec  141 MBytes  1.18 Gbits/sec
                                                              > [  5][TX-C]  7.00-8.00  sec  149 MBytes  1.25 Gbits/sec
                                                              > [  7][RX-C]  7.00-8.00  sec  140 MBytes  1.17 Gbits/sec
                                                              > [  5][TX-C]  8.00-9.00  sec  146 MBytes  1.23 Gbits/sec
                                                              > [  7][RX-C]  8.00-9.00  sec  139 MBytes  1.16 Gbits/sec
                                                              > [  5][TX-C]  9.00-10.00  sec  150 MBytes  1.26 Gbits/sec
                                                              > [  7][RX-C]  9.00-10.00  sec  141 MBytes  1.18 Gbits/sec
[  5]  0.00-10.00  sec  2.74 GBytes  2.35 Gbits/sec    0    | [  5][TX-C]  0.00-10.00  sec  1.48 GBytes  1.27 Gbits/sec
[  5]  0.00-10.00  sec  2.73 GBytes  2.35 Gbits/sec          | [  5][TX-C]  0.00-10.00  sec  1.48 GBytes  1.27 Gbits/sec
                                                              > [  7][RX-C]  0.00-10.00  sec  1.35 GBytes  1.16 Gbits/sec
01:00.0 PCI bridge: ASMedia Technology Inc. ASM1182e 2-Port PCIe x1 Gen2 Packet Switch
02:03.0 PCI bridge: ASMedia Technology Inc. ASM1182e 2-Port PCIe x1 Gen2 Packet Switch
02:07.0 PCI bridge: ASMedia Technology Inc. ASM1182e 2-Port PCIe x1 Gen2 Packet Switch
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller
04:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller
root@OpenWrt:~# iperf3 -c 192.168.1.199                      | root@OpenWrt:~# iperf3 -c 192.168.1.199 --bidir
[  5] local 192.168.1.1 port 35590 connected to 192.168.1.199 | [  5] local 192.168.1.1 port 57102 connected to 192.168.1.199
[ ID] Interval          Transfer    Bitrate        Retr  C | [  7] local 192.168.1.1 port 57106 connected to 192.168.1.199
[  5]  0.00-1.01  sec  158 MBytes  1.32 Gbits/sec    0    | [ ID][Role] Interval          Transfer    Bitrate        R
[  5]  1.01-2.00  sec  166 MBytes  1.40 Gbits/sec    0    | [  5][TX-C]  0.00-1.00  sec  128 MBytes  1.08 Gbits/sec
[  5]  2.00-3.01  sec  168 MBytes  1.40 Gbits/sec    0    | [  7][RX-C]  0.00-1.00  sec  124 MBytes  1.04 Gbits/sec
[  5]  3.01-4.00  sec  165 MBytes  1.39 Gbits/sec    0    | [  5][TX-C]  1.00-2.00  sec  138 MBytes  1.15 Gbits/sec
[  5]  4.00-5.01  sec  168 MBytes  1.40 Gbits/sec    0    | [  7][RX-C]  1.00-2.00  sec  133 MBytes  1.11 Gbits/sec
[  5]  5.01-6.00  sec  166 MBytes  1.40 Gbits/sec    0    | [  5][TX-C]  2.00-3.00  sec  138 MBytes  1.15 Gbits/sec
[  5]  6.00-7.00  sec  168 MBytes  1.40 Gbits/sec    0    | [  7][RX-C]  2.00-3.00  sec  133 MBytes  1.12 Gbits/sec
[  5]  7.00-8.01  sec  168 MBytes  1.40 Gbits/sec    0    | [  5][TX-C]  3.00-4.00  sec  138 MBytes  1.15 Gbits/sec
[  5]  8.01-9.00  sec  166 MBytes  1.40 Gbits/sec    0    | [  7][RX-C]  3.00-4.00  sec  132 MBytes  1.11 Gbits/sec
[  5]  9.00-10.00  sec  168 MBytes  1.40 Gbits/sec    0  1 | [  5][TX-C]  4.00-5.00  sec  138 MBytes  1.15 Gbits/sec
                                                              > [  7][RX-C]  4.00-5.00  sec  132 MBytes  1.11 Gbits/sec
                                                              > [  5][TX-C]  5.00-6.00  sec  138 MBytes  1.15 Gbits/sec
                                                              > [  7][RX-C]  5.00-6.00  sec  132 MBytes  1.11 Gbits/sec
                                                              > [  5][TX-C]  6.00-7.00  sec  136 MBytes  1.14 Gbits/sec
                                                              > [  7][RX-C]  6.00-7.00  sec  132 MBytes  1.11 Gbits/sec
                                                              > [  5][TX-C]  7.00-8.00  sec  139 MBytes  1.16 Gbits/sec
                                                              > [  7][RX-C]  7.00-8.00  sec  133 MBytes  1.12 Gbits/sec
                                                              > [  5][TX-C]  8.00-9.00  sec  138 MBytes  1.15 Gbits/sec
                                                              > [  7][RX-C]  8.00-9.00  sec  132 MBytes  1.11 Gbits/sec
                                                              > [  5][TX-C]  9.00-10.00  sec  139 MBytes  1.16 Gbits/sec
                                                              > [  7][RX-C]  9.00-10.00  sec  133 MBytes  1.12 Gbits/sec
[  5]  0.00-10.00  sec  1.62 GBytes  1.39 Gbits/sec    0    | [  5][TX-C]  0.00-10.00  sec  1.34 GBytes  1.15 Gbits/sec
[  5]  0.00-10.00  sec  1.62 GBytes  1.39 Gbits/sec          | [  5][TX-C]  0.00-10.00  sec  1.33 GBytes  1.15 Gbits/sec
                                                              > [  7][RX-C]  0.00-10.00  sec  1.29 GBytes  1.11 Gbits/sec
  FreeBSD support mfree 2 3,688 02-04-2022, 09:29 AM
Last Post: monwarez
