FreeBSD support
Anyone know if someone is working on FreeBSD or other BSD on Quartz64 ?
I see that there is no BSD section for Quartz64, but i suppose this will be added later when someone will start working on it ?
Thank you
(08-02-2021, 05:45 AM)mfree Wrote: Hello,
Thank you
Quartz64 still in early stage. Give about 2-3 months, for sure BSD development will start.
For those interested, thanks to https://github.com/jaredmcneill/quartz64_uefi it is possible to boot FreeBSD stable 2022_feb_03 without specific patches.
You will have to put the edk in a sd card, and the FreeBSD installer in usb.
Unfortunately there will be no Ethernet support out of the box, but you get hdmi output. If you need internet connectivity I guess that a usb to ethernet adapter should work, I tested with my phone as an usb modem and it work well.
  OpenWrt support mj22226 2 2,254 05-21-2022, 01:55 PM
Last Post: mj22226
