Checking Keyboard Charging Status
So I have my PPP in the keyboard case, and the keyboard is working :-)
I have connected the keyboard to a power supply.
The battery indicator at the top right of the menu bar is showing not charging (63%).
"cat /sys/class/power_supply/battery/status" shows Discharging
"cat /sys/class/power_supply/battery/capacity" shows 63
"cat /sys/class/power_supply/ip5xxx-charger/status" shows Charging
"cat /sys/class/power_supply/ip5xxx-charger/capacity" shows 81
So my assumption is that the keyboard case is charging itself while the phone is running on it's internal battery - would that be correct?
  Keyboard not working PPP is support broken atm? joshndroid 13 3,466 02-24-2024, 01:59 PM
Last Post: mburns
  The XIT bluetooth folding keyboard can work with the Pinephone Pro mburns 0 296 11-09-2023, 10:57 AM
Last Post: mburns
  Fixing the PinePhone Keyboard for the Linux Console mburns 0 516 09-02-2023, 07:48 AM
Last Post: mburns
  Keyboard charges, won't type - ERROR: I2C_RDWR failed: No such device or address jovval 0 475 07-10-2023, 08:11 AM
Last Post: jovval
Bug Keyboard Power Issues Merc 13 8,250 05-02-2022, 09:41 AM
Last Post: dgiffin
  Use keyboard case as virtual mouse EwigeBlumenkraft 1 1,958 03-24-2022, 05:22 AM
Last Post: magdesign
  Hardware keyboard top row keycodes problem cyrelk 2 2,353 03-03-2022, 03:01 AM
Last Post: cyrelk
  Keyboard case issues dgiffin 10 7,309 03-03-2022, 12:56 AM
Last Post: tcoulon
  Keyboard Not Charging PPP thismarty 7 5,390 02-09-2022, 04:32 PM
Last Post: thismarty
  Keyboard Case Not Typing in Mobian thismarty 5 3,669 02-06-2022, 01:52 AM
