Keyboard Case Not Typing in Mobian
Keystrokes on my keyboard case are registered on my PPP in Manjaro BUT keystrokes are not registered on the official PPP build of Mobian (January 16 daily).
Since Mobian is listed as one of the OS's that should support typing on the keyboard case, I assume it should work.
I've ...
1.  Updated, upgraded, dist-upgraded, and re-flash the SD card
2.  I've re-seated the keyboard
3.  I've POGO-shimmed the keyboard
Yet no matter what, Mobian doesn't seem to hear my keystrokes from the keyboard, while (notably) Manajaro does.
Any suggestions?
TIA!
Same here
Should be working now with the new kernel update.
(02-05-2022, 05:17 PM)Fish Wrote: Should be working now with the new kernel update.
Thanks for the (hopefully) good news, Fish!
So, when does that kernel update drop?
There hasn't been a new daily build posted for Mobian PPP since Jan16, and I'm all update'd, upgrade'd and dist-upgrade'd.
 - but still no keypresses.
To be honest, I still have to test it with my keyboard case and PPP. But I follow the mobian chat and there it was mentioned that the keyboard case was functioning with a new kernel update.
Woo-hoo!
The new firmware did the trick - I can now type in Mobian.
Now if only my keyboard case's battery would charge ...
  Availability of the LoRa addon case in pine64 shop deuitpym 1 95 04-15-2024, 04:49 AM
Last Post: zetabeta
  Keyboard not working PPP is support broken atm? joshndroid 13 3,361 02-24-2024, 01:59 PM
Last Post: mburns
  The XIT bluetooth folding keyboard can work with the Pinephone Pro mburns 0 277 11-09-2023, 10:57 AM
Last Post: mburns
  Pinephone Pro battery case deedend 2 726 09-25-2023, 06:05 PM
Last Post: deedend
  Fixing the PinePhone Keyboard for the Linux Console mburns 0 495 09-02-2023, 07:48 AM
Last Post: mburns
  Is the NFC case dream still alive? cgbarros 1 681 08-13-2023, 04:43 AM
Last Post: fxc
  Keyboard charges, won't type - ERROR: I2C_RDWR failed: No such device or address jovval 0 453 07-10-2023, 08:11 AM
Last Post: jovval
Bug Keyboard Power Issues Merc 13 8,134 05-02-2022, 09:41 AM
Last Post: dgiffin
  Checking Keyboard Charging Status dgiffin 0 1,202 04-23-2022, 03:40 AM
Last Post: dgiffin
  Use keyboard case as virtual mouse EwigeBlumenkraft 1 1,915 03-24-2022, 05:22 AM
Last Post: magdesign
