PBP not booting anymore
Hello
I have copied the image (booting form SD, using dd) to the eMMC. The image file is exactly the same as was used to flash the SD card.
After this has been done, the PBP does not boot anymore (neither eMMC, nor SD). The power LED stays amber, nothing happening.
Any hints?
Are you still able to boot from SD?
(04-18-2022, 08:43 AM)tophneal Wrote: Are you still able to boot from SD?
No, booting from SD is also not possible.
I assume I broke the eMMC (or better it's content). From what I read the images working on a SD do not work on eMMC. I proably have to wait until the eMMC-USB adapter arrives, wipe the first n bytes, and try to boot again.
Err, this is not intrinsically true, I suspect a mismatch between uboot and distro
(I assume that image was written to emmc 'correctly')
Nearly all SD boots are using uboot from emmc, since 1st uboot found is the one used
Test, by removing/disable emmc, see if SD will boot
The eMMC-USB adapter arrived today. I have used dd to write an image (which was classified as an emmc-installer) to eMMC.
Once done, booting (from eMMC and SD) was possible again.
(04-21-2022, 11:00 AM)jsch Wrote: The eMMC-USB adapter arrived today. I have used dd to write an image (which was classified as an emmc-installer) to eMMC.
just a friendly note: emmc-installer images are typically meant to be booted from SD and used to install an OS to the emmc. You may be booting up to a TTY guided installation. If you do, wipe the emmc, write the eemc installer img to SD, and then boot to SD and go through the guided installer.
  Issue with booting Manjaro from encrypted NVMe drive on pbp Cs137 1 971 08-18-2023, 01:58 AM
Last Post: juliamenendez
  Fix for Armbian not booting on PBP from eMMC agreenbhm 7 3,842 04-01-2023, 02:58 PM
Last Post: TRS-80
  Booting Arch from USB lorebett 6 3,006 09-18-2022, 11:35 AM
Last Post: lorebett
  pinebook pro not booting cricket 1 1,186 08-17-2022, 04:38 PM
Last Post: cricket
  Problems installing/ booting a different Linux on PinebookPro v-man 3 3,087 03-22-2022, 06:37 PM
Last Post: pentamassiv
  NVMe timeout when booting from eMMC but not SD satwell 5 5,578 10-29-2021, 07:41 AM
Last Post: psstoev
  Trouble booting in Gentoo tdiggitydog 11 7,296 07-20-2021, 10:16 PM
Last Post: moonwalkers
  Manjaro wont recognize eMMC after booting with it disabled peasant 1 2,087 06-27-2021, 02:39 AM
Last Post: Arwen
  UBOOT - Mainline not booting from SD card / BSP OK Anarethos 1 2,937 01-10-2021, 12:33 AM
Last Post: Anarethos
  Graphic problems when booting Debian crecker 1 2,918 12-15-2020, 06:39 PM
Last Post: marszal
