PBP Can't Boot Up
Dear Pine64 Community,
I really really love PBP. But, it's dead, unable to boot up.
I'm not sure what I did that caused PBP dead.
I have done all Wiki and steps to reset, bypass the power and reset again. None of this worked.
Please kindly advise. Thanks.
(04-17-2022, 09:23 PM)iscmob Wrote: Dear Pine64 Community,
So I assume it did boot before and you haven't changed the installed OS.
Did you boot it after a long period of inactivity?
Did you let it charge for a full day?
I have PBP for a year plus, working fine until I tried to change the software (fr Debian to others).
It had intermittent boot problem (ie sometimes it could boot up and sometimes it couldn't). Then I did the reset according to our Wiki page.
And the problem persisted. Then I remove the ribbon cable to the small MB and connect the Power Bridge Connector. This didn't work.
Thus, I had done all available steps on our Wiki to jump start PBP, still PBP cannot be revived.
Do you have a USB adapter for the eMMC?
Can you try to flash the original Debian image on the eMMC?
I do have a USB adapter and did reflash the eMMC. Still, it didn't solve the problem.
Is there a way to disassemble the whole laptop and check each component,  aseemble it back?
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 1,286 12-18-2025, 01:05 AM
Last Post: qingss0
  Bonk to boot biketool 2 1,866 10-21-2025, 09:08 AM
  3 days in, slow/stuck or no boot. lgmpbp2 34 28,410 06-11-2025, 08:53 AM
Last Post: lgmpbp2
  upgrading u-boot--what version? where to get it? bsammon 14 17,657 04-03-2025, 07:47 AM
Last Post: Tazdevl
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 11,864 12-27-2024, 11:38 AM
Last Post: akash3995
  broken tow-boot hashkeeper 1 4,038 12-25-2024, 10:12 PM
Last Post: jessipinkman
  Cant boot into an OS trashtendenz 3 5,273 10-23-2024, 03:49 AM
Last Post: chaylengordon
  Unable to boot? YossiS 4 3,923 09-04-2024, 10:35 AM
  uboot wont boot to SD card after upgrade jbradley419 7 8,413 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 2,533 01-16-2024, 09:17 AM
Last Post: jbradley419
