Pinenut power consumpiton
I'm interested in real life data how much power PineNut need to operate.
My plan was to use them as solar powered ground moisture meters. They gonna wake up, and then report to base how wet/dry are ground, and go sleep back.
Also I'm not sure if i  gonna play with BT LE mesh or just use WiFi. Size of grass is around 10x20m.
I need some real life data to decide if making it solar powered is possible or not.
  Firmware Update for PinePower Desktop Power Cycling Issue TimothyRodriguez 1 96 05-03-2024, 12:53 AM
Last Post: Pavlos1
  Link USB power strips for a cluster? shanefe 1 271 04-02-2024, 11:11 PM
Last Post: evilbunny
  [Article] Star64 JH7110: Power Up the Display Controller with U-Boot Bootloader lupyuen 0 692 09-02-2023, 10:13 AM
Last Post: lupyuen
  Pine Desktop PowerSupply wont power on BSharp 5 1,837 08-29-2023, 08:06 AM
Last Post: chickenplusone
  power/battery usage on risc-v vs arm64? zetabeta 1 805 08-28-2023, 01:23 AM
Last Post: alphonso
  Link USB power strips for a cluster? DevonBirch 4 3,483 08-10-2023, 09:11 PM
Last Post: halibutdreary
  Plans for higher Power PinePowers PMARC14 0 553 07-14-2023, 03:03 PM
Last Post: PMARC14
  The power of the Star64 vs Pinebook Pro/RockPro64 Starfall 1 1,173 04-17-2023, 05:00 AM
Last Post: lkoini
  Possible Uninterruptible power supply for Pine64's SBC's GreyLinux 10 5,366 02-11-2023, 03:15 AM
Last Post: ToryRutter
  PinePower USBench concept: Usb C universal/lab power supply (=48V5A PD 3.1 trigger) ijsbeer 3 3,025 04-16-2022, 04:59 PM
Last Post: ijsbeer
