03-23-2022, 04:14 AM
Daily test builds: https://imola.armbian.com/dl/quartz64a/nightly/
Armbian and LibreELEC and AltLinux for Quartz64
04-01-2022, 07:36 AM
New versions 20220331 with kernel 5.16.18 and 5.17.1
04-04-2022, 05:43 AM
Test version of Libreelec for Quartz64.
![]() https://disk.yandex.ru/d/nLZ6UCxUpWMMUQ Please note, there is no bootloader in the image, the launch works only when using new versions of u-boot from Armbian. If you have the Armbian version installed in eMMC, you can use any media (SD card or USB media) to run LE. Or use a bundle of SD card with Armbian + USB media with LE. At the moment there is a problem with HW decoding, so you need to disable hardware DRM in the player settings. The capabilities of the rk3566 processor are quite enough for software decoding up to 1440p, I checked different videos, they work without brakes. I hope to solve this problem soon, because HW is already working on Station P2\M2, I need to find what is missing in DTB for Qurtz64a.
04-04-2022, 06:51 AM
Great if i found my clock back
![]() i try a attempt ![]() perhaps &vpu { status = "okay"; }; &vdpu_mmu{ status = "okay"; }; is see that you patch that in k356x.dtsi but not okay or disabled in the device dts . but that dont explain why p2/m2 works and quartz not (04-04-2022, 06:51 AM)shaggy013 Wrote: Great if i found my clock back Adding parameters does not change anything (they are already included). I think the reason is rk809 != rk817 and you need to look at the code. After playing with the DTB parameters, I get "static noise" in cases where HW decoding should work. Updated the LE version. The HW decoder works, but you need to switch the DPM plan mode to EGL in the media player settings. ![]()
04-05-2022, 02:12 AM
I checked running the latest versions of AltLinux on Quartz64.
![]() The system starts up and works normally. The startup principle is similar to the Libreelec startup mechanism described above. For those who have Armbian installed on eMMC with support for launching any systems from USB \ SD, the launch is very simple. Download the image, unpack and burn the image to a USB\SD device, connect to Quartz64 and turn on the power. The system starts automatically. Please note, this is initial support, the initial launch before the image appears on the screen can take up to 30-60 seconds. https://disk.yandex.ru/d/7efAT4uD6VEpxw
04-05-2022, 06:30 AM
well there are some diffrence between a rk809 and a rk817 boost, a switch etc
and some board dont even have one of them and why the strange uboot construction future spi thoughts ? nice more distro's ![]() with a box-demo dts and the ir and vfd in the overlay you can get a lot of tvboxes happy https://github.com/warpme/minimyth2/comm...cd0af867cd if i can reanimate my board i will check them ![]()
04-05-2022, 06:59 AM
Conducted glmark2 tests using the AltLinux system and the regular-workstation-arm image.
When using the default 5.16 kernel, the result is modest, only 25. But after simply replacing only the 5.17 kernel with files from the latest version of Armbian, the result is 225, very good for the initial launch without optimization. ![]() Code: ======================================================= (04-05-2022, 06:30 AM)shaggy013 Wrote: well there are some diffrence between a rk809 and a rk817 boost, a switch etc >and why the strange uboot construction future spi thoughts ? I use a machine translator and did not understand what the essence of the question is. >with a box-demo dts and the ir and vfd in the overlay you can get a lot of tvboxes happy it won't work, TV boxes are full of shit (I've worked a lot with different ones and I know well what it is). they die after a few months of intensive work. I no longer waste time on this empty work, there is no practical use in it, after a few weeks you realize that you have wasted money and are already buying normal devices with normal support. I discovered a funny phenomenon. I compared the glmark2 Armbian tests (Ubuntu Jammy and Debian Sid) and Altlinux (I use the same kernel on both systems). Armbian's results are 100, and AltLinux's are 225-370 . I haven't figured out why there is such a difference yet. I have only one instance of Quartz64 with 4GB of RAM, it would be interesting to compare the behavior on models with 8GB of RAM. Code: =======================================================
04-06-2022, 02:30 PM
Ow i mean with booting from usb etc with the armbian uboot on a sd or emmc for le , what is the use of that ? , to force armbian with le on a device
and the only thing i could think of is a special uboot for on a spi yeah tv-boxes world is lot of bad products , it was just a thought they had 1 or 2 months ago a discussion about glmark and from what i get from that is to use the same version on both distros wayland,xorg https://repology.org/project/glmark2/packages lot of glmark2 2021.02 versions and sadly i cant say i have 4Gb ![]() DDR Version V1.11 20211103 ln unknown device error ERR once i figured that issue out power or memory ![]() |
crux-arm Quartz64 RK3566 (aarch64) | mara | 4 | 1,687 |
Yesterday, 08:44 AM Last Post: mara |
slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) | mara | 46 | 12,430 |
06-27-2022, 12:29 PM Last Post: mara |
Armbian on Quartz64 | dieselnutjob | 34 | 8,000 |
03-17-2022, 06:29 AM Last Post: balbes150 |
