03-11-2022, 10:10 PM
I'm unsure if this is only affecting the PPP but I'm unable to do anything but connect to the network. Searching for anything just crashes the tab.
Constant TOR tabs crashing
03-12-2022, 04:32 PM
(This post was last modified: 03-12-2022, 05:06 PM by Dendrocalamus64.)
OS? Tor browser version?
In any case, I have this on the Pinebook Pro running Manjaro since the last Manjaro update. Using the unofficial builds from here. Tor Browser 11.0.6 was working fine until the Manjaro update, then that broke something. Haven't tried 11.0.7 yet. Workaround: Open about:config, set browser.tabs.remote.autostart to false, then close & relaunch the browser. The first tab to open still gives the stupid error message, but then it works for me.
03-13-2022, 07:10 PM
(This post was last modified: 03-13-2022, 07:14 PM by 8371879189758960.
Edit Reason: making it more clear
Forgot to mention yes I'm on manjaro phosh but thanks tons for the help! I wonder if changing this setting affects security/more identifiable fingerprint?
03-14-2022, 11:09 AM
(This post was last modified: 03-14-2022, 01:15 PM by Dendrocalamus64.)
You can see the effect in about:support:
Code: Multiprocess Windows: 0/1 instead of, Code: Multiprocess Windows: 1/1 In theory it's supposed to reduce stability, performance & security. I don't think it would be the easiest thing to fingerprint, especially if nobody is looking for it. You could try running Mobian on the phone, I preferred it to Manjaro the last time I was using my PinePhone, and I think this is a Manjaro-specific problem.
03-14-2022, 11:20 AM
Thank you for the info! I've been trying to get Mobian to work on my external sd card but after it says "done" during installation and turns off, I can't get it to turn back on so I wanted to wait until the next weekly (was hoping it was coming out yesterday).
03-14-2022, 07:25 PM
Maybe it's related to this?
Quote:PinePhone Pro Specific
03-14-2022, 08:46 PM
That got it going! Will be nice if one day we can have a prompt on boot allowing us to select which distro we want to boot from/which memory.
PPP Phone rings with constant vibrate - turn off vibrate | henrythemouse | 0 | 861 |
05-16-2022, 03:59 PM Last Post: henrythemouse |
