Using Keyboard Case with Arch (DanctNix) (complete instructions)
I recently installed Megi's userland keyboard driver on the PinePhone running Mobian. What I really wanted to do was get my pinephone and keyboard case running as a mini-computer with a CLI (no GUI). I discovered DanctNIX barebones Arch Linux image and finally got the userland driver running on that also. So this is a complete list of steps required to do so. You can find all of this information in various places, but I'm hoping it's handy to have it all in one location for someone...
1. Fix the keyboard case's pogo pads
First, the hardware of the keyboard needs to be hacked a bit. It won't work out-of-box. Locate the Pogo pin pads in the back cover of the new keyboard case where the phone's pogo pins are supposed to make contact. The pogo pads on the keyboard case will not make contact with the pogo pins on the back of the phone unless you do something to raise the pads.
I carefully pried the plastic holding the pogo pads from the back of the case and slipped a small folded strip of paper beneath them. The plastic holding the pads is glued to the case (which will be the new back of the phone case) and can be pried away carefully. There were no screws in my keyboard case holding the pogo pads.
reference https://xnux.eu/pinephone-keyboard/faq.html#ts in the troubleshooting section at the bottom.
2. Install Arch Linux
Arch Linux ARM builds for pinephone (and PPPro and other devices) are located here: https://github.com/dreemurrs-embedded/Pi...h/releases The latest versions include kb151, the i2c keyboard driver needed by the pinephone's keyboard case. I installed the barebones version which merely boots to a tty and the rest of these instructions are specifically for CLI.
I used the Jumpdrive method which is documented here: https://wiki.pine64.org/wiki/PinePhone_I..._JumpDrive
Connect to your local WIFI...
$nmtui
Select Activate Connection, then select your WIFI and enter password. You can use the arrow keys to move around the TUI (FN+> is UP, FN+{ is DOWN, FN+" is LEFT, and FN+} is RIGHT).
Determine your pinephone's IP address...
$ip a
Look for the ip address for the WLAN0 network connection.
For simplicity, SSH into your pinephone from a linux PC (x.x.x.x is the ip address of your pinephone)...
$ssh alarm@x.x.x.x
Update and upgrade with the following:
$ sudo pacman -Syu
Install some stuff you'll need...
$ sudo pacman -S nano terminus-font git gcc php make
3. Rotate the screen and increase font size
Still SSH'ing into your pinephone...
$ cd /boot
$ sudo nano boot.txt
Locate the line starting with setenv bootargs... This is a list of kernel parameters. Append the following to the end of the list (include a single space to separate it from the prior parameter). The fbcon parameter will rotate your screen 90 degrees clockwise putting it in landscape mode and the kb151 parameter will effectively disable kb151 so we can use the userland driver, which we'll install later. (if you're entering all this from the pinephone keyboard case, don't do the kb151 parameter yet, or make sure you finish everything before rebooting).
fbcon=rotate:1 kb151.disable_input
(Megi added a second fbcon parameter to set the font, but I wasn't able to get this to work, so I added it to the system-wide bash script, which we'll get to in a second....)
To save changes and close Nano, type CTRL-X, Y, and Enter.
back on the command line, run the following to update the boot.scr file from boot.txt...
$ sudo ./mkscr
Reference https://xnux.eu/log/#058 regarding disabling kb151; I tried a couple other methods, but only this one worked.
Add a setfont step to the system wide bash login script /etc/bash.bashrc...
$ sudo nano /etc/bash.bashrc
Add the following line at the end of the file to change the tty font to Terminus c32n (or whatever you like)...
setfont ter-c32n
4. Download, build, and install the userland driver
$ git clone https://mff.cz/git/pinephone-keyboard/
$ cd pinephone-keyboard
$ make
Now we write the systemd unit file...
$ sudo nano /etc/systemd/system/ppkb-i2c-inputd.service
Enter the following into this new .service file...
  [Unit]
  Description=Pinephone Keyboard Service Daemon
  [Service]
  Type=simple
  ExecStart=/home/mobian/pinephone-keyboard/build/ppkb-i2c-inputd
  [Install]
  WantedBy=multi-user.target
Now we enable this service the next time we boot with ...
$ sudo systemctl enable ppkb-i2c-inputd.service
Reference https://wiki.mobian-project.org/doku.php...-case-ppkc regarding runningn this userland driver as a systemd service.
5. Reboot and test
You're done.
$ sudo reboot
When the system reboots, it will still load kb151, but that driver will be disabled. The systemd service ppkb-i2c-inputd will be loaded by systemd and be the driver for the new keyboard case.
Use the Pine key (pinecone symbol) with number keys to enter FN keys. Try it out by typing CTRL-ALT-PINE-2 to switch to tty2 and then CTRL-ALT-PINE-1 to switch back to tty1 which is the default tty.
Just a reminder that step 4 can be replaced with "install ppkb-tools package and then enable the systemd service".
Find me in the forest, when I'm at my lowest. I don't really think you should continue..
HOLD YOUR BREATH.
(02-25-2022, 01:54 AM)Danct12 Wrote: Just a reminder that step 4 can be replaced with "install ppkb-tools package and then enable the systemd service".
Thanks to both of you.  Unfortunately though, my keyboard doesn't work at all now!  Have I missed something?
I started with a fresh arch phosh, updated it (keyboard worked at this stage).  Installed ppkb-tools via pacman, enabled the service, rebooted.  But now nothing at all from the keyboard, except the charging.
Ideas appreciated Smile
(Pinephone OG, first CE after Braveheart)
Mind posting a photo of your shims? When I shimmed the keyboard, it stopped working on my Pro but started working on my PinePhone (though only the keyboard, no charging). So I would like to see what a successful shim looks like for reference.
I'm not familiar with ppkb-tools. That sounds like if would have made things easier. But I know from experience that you can't have both the userland driver AND kb151 at the same time or the keyboard won't work. So perhaps you need to add "kb151.disable_input" to your boot.scr. Step 3 shows how to modify kernel parameters to do this.
(02-25-2022, 09:08 AM)ragreenburg Wrote: Mind posting a photo of your shims? When I shimmed the keyboard, it stopped working on my Pro but started working on my PinePhone (though only the keyboard, no charging). So I would like to see what a successful shim looks like for reference.
I think this comes down to raising the 6 pogo pins and I apologize for my reluctance to undo my shim and redo it, but I will describe what I did as best as I can.
First, carefully pry the circled area away from the case. It is secured with glue and will pry away. Do it slowly, being sure not to break the plastic. It only needs to be pried away enough to slide a piece of paper folded a couple of times so that the paper shim can be slid from the right side back beneath the pogo pads on the far left so that all pogo pads are raised.
I cut a strip of paper that was narrower than the blue lines, which it will need to slide between (from the right side of the pogo pads). I folded this small strip of paper twice, so it was 4x thickness and about the size of the pogo pads. Then I slid it under the pogo pads from the right side, sliding between the two raised plastic pieces that surround the pogo pad plastic and angling it 'north'.
Here's a pic from an angle that is supposed to show how the plastic holding the pogo pads is now warped by the shim beneath it, forcing the pogo pads away from the back of the case to make better contact with the pogo pins on the back of the phone.
Sorted!  In my haste, I missed those steps.
I've now edited the boot.txt filed, did sudo ./mkscr, rebooted, and it works.
The output of the number row with fn or shift is now correct (if I use US keyboard in settings), and Pine+F1-F10 seems to work fine too.  Hurrah!
Just need to set it so my scaling and virtual keyboard settings aren't forgotten on reboot, and then I can properly start making use of this thing.
Thanks again.
Thank you for the pictures! When I tried pushing the paper underneath that pin pad I got a lot of resistance and didn't want to push any farther because I thought there was a ribbon cord there(?) and didn't want to brick the keyboard. Is there anything under the pin pad to keep an eye out for?
(02-25-2022, 12:05 PM)ragreenburg Wrote: Thank you for the pictures! When I tried pushing the paper underneath that pin pad I got a lot of resistance and didn't want to push any farther because I thought there was a ribbon cord there(?) and didn't want to brick the keyboard. Is there anything under the pin pad to keep an eye out for?
I believe the resistance you are encountering is the glue. I was able to raise the plastic tab holding the pogo pads enough to slide a piece of paper all the way under the left-most pogo pads. So I believe the ribbon extends from the left of the pogo pads, not from directly beneath them.
$nmtui
$ip a
$ssh alarm@x.x.x.x
$ sudo pacman -Syu
$ cd /boot
$ sudo ./mkscr
setfont ter-c32n
$ make
  [Unit]
  [Service]
  Type=simple
  [Install]
5. Reboot and test
You're done.
$ sudo reboot
I made good use of your post, thanks for putting it up. However, two things in
Step 3 didn't work for me:
3. Rotate the screen and increase font size.
  The cmd to update boot.scr...
  X $ sudo ./mkscr (didn't work)
    $ sudo pp-uboot-mkscr (did work)
  The cmd to change the font...
    Editing /etc/bash.basrc
  X $ sudo nano /etc/bash.bashrc (didn't work)
    The FONT variable in /etc/vconsole.conf is used to set the font at boot,
    persistent for all consoles.
      $ sudo nano /etc/vconsole.conf (did work)
        FONT=ter-c32n
        FONT_MAP=8859-2
  Case for Pinephone totilele 13 7,547 04-11-2024, 11:48 AM
Last Post: gramonyl
  Slip/Zippered Case for PP/KB? jakfish 0 302 03-03-2024, 04:55 PM
Last Post: jakfish
  keyboard case charging but not typing new2pinephone 18 5,961 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 10,265 01-14-2024, 03:34 PM
Last Post: acid andy
  I've added an I2C connector to the PP keyboard eugenr 0 452 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,270 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 470 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,282 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 539 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 640 10-21-2023, 02:55 AM
