No underscore on pinephone keyboard
Running a community edition pinephone using mobian bookworm on my new keyboard. Everything appears to be working with the exception of having an underscore character. Cannot type name_pine in any app. Really need access to this character for terminal. Any ideas or comments are appreciated. Thanks
At least with the userspace driver hitting Fn-9 yields the underscore. (Not sure about the kernel driver, have not used that in a while now.)
I faced the same problem at first.
Digging through Megi's code led me to the answer.
Just holding Fn+9 isn't enough, the right key combination is:
Fn+(Left)Shift+9.
Let me know if this works out for you as well.
Greetings Jasper
It worked. Thanks
I will post as solved.
  Pinephone - broken power button rorus 14 22,977 05-17-2026, 03:52 PM
Last Post: EuvzO8
  Pinephone + Keyboard for sale, little use ruemoo 15 10,575 03-05-2026, 10:14 AM
Last Post: diazman39
  PinePhone 16 GB – Free to a Good Home Anna 2 1,298 01-20-2026, 01:43 PM
Last Post: Anna
Bug PinePhone modem keeps "disappearing" Kevin Kofler 17 19,020 12-12-2025, 03:27 AM
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 4 7,479 12-11-2025, 08:57 AM
Last Post: jakfish
  Recycling pinephone as home server mdk 6 2,588 12-01-2025, 02:57 AM
Last Post: mdk
  PinePhone, PinePhone Pro, Keyboard/Accessories for sale brb78 5 1,970 11-30-2025, 05:45 AM
  Modem Issues with the Pinephone Temmie19 5 5,381 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 3,807 06-21-2025, 05:19 PM
Last Post: mikeb
  Pinephone not booting sd card... bruv 1 2,779 03-25-2025, 08:51 PM
