Android Lunch Menu
To build for the PineNote, what option should I pick from the lunch menu? There are 4 options, that mention eink, and I don't see anything in the Wiki:
12. rk3566_eink-user
13. rk3566_eink-userdebug
14. rk3566_einkw6-user
15. rk3566_einkw6-userdebug
Or is the correct option one of the other options?
Thanks,
XenosCR
(02-07-2022, 09:39 PM)xenoscr Wrote: Hello xenoscr,
Based on the provided options, if you are building for the PineNote with an e-ink display, you should likely choose one of the "rk3566_eink" options. If you're unsure, consider reaching out to the PineNote community or support for specific guidance.
Question How to write handwriting note app that not delay in android app for PineNote? wannaphong 0 4,567 10-30-2022, 07:29 AM
Last Post: wannaphong
  Has anyone tried the Android Xournal++? miak 4 13,339 02-22-2022, 03:42 PM
Last Post: TRS-80
  Guide: Access Android Settings /ADB in stock image nakato 0 5,726 12-23-2021, 05:50 AM
Last Post: nakato
