SMS app
So I have a Mint mobile sim card in my PPP running Manjaro. I can make calls send/receive texts, MMS not working but I am not surprised and can work with that. I downloaded modem manager GUI and it shows my modem but says mint is disconnected even though I can do everything with it. Is there something wrong with it saying im disconnected ?
Also I can reply to texts with spacebar just fine but if I try to send a new text it puts it a group type chat with all my contacts. Are there any other any other sms apps I could try ?
Thanks,
Byron
I'm running Manjaro Phosh with Mint sim on PPP.
I go into settings, enable mobile data, and set my APN:
APN: Wholesale
Then open up terminal and run "sudo pacman -S mmsd-tng"
This enables MMS
Then reboot the phone so that it is working, open up chatty and and enter the APN settings for MMS under preferences
http://wholesale.mmsmvno.com/mms/wapenc
More info on Mint's APN settings here:
https://www.mintmobile.com/setup/android/
I'm not sure which version of Manjaro you are running, but I assume entering the correct APN settings should work for Manjaro plasma similarly. I can send and receive MMS and group chats fine as well as browse the internet over 4G LTE
(02-07-2022, 02:23 AM)lllsondowlll Wrote: I'm running Manjaro Phosh with Mint sim on PPP.
APN: Wholesale
This enables MMS
I'm running the stock Manjaro for now, I've tried most of the distros out now and prefer this in the early stages of all of them.
I will try what you said when I get off today.
My main thing is finding an app that works, when I'm in phone book and clock send message, it say no device to connect to. Is there a fix for that?
APN: Wholesale
This enables MMS
I'm not sure, I hopped away from the Manjaro Plasma to Manjaro Phosh since I had the phone for stability and functionality. Manjaro plasma is still a bit buggy and unpolished. I can send and receive calls, text messages, group chats, and pictures via MMS on Manjaro Phosh. For whatever questions you have for Plasma I have no idea.
