Switchng to Mobian from Manjaro on PPPro for test run
Based on what I have observed in the last week I will flash my PPPro (which I use as my DD) with the Mobian 20220109 weekly image and see how it compares w. the Manjaro image.
(01-11-2022, 01:57 PM)iwm Wrote: Based on what I have observed in the last week I will flash my PPPro (which I use as my DD) with the Mobian 20220109 weekly image and see how it compares w. the Manjaro image.
(Edit: Turned out to just be a power issue)
Did it boot for you?
I just tried this image and it does not boot propperly.
I only get:
[    1.555695] hub 2-0:1.0: USB hub found
[    1.556056] hub 2-0:1.0: 1 port detected
U-Boot TPL 2021.10+dfsg-1mobian3 (Dec 05 2021 - 21:17:03)
Channel 0: LPDDR4, 50MHz
BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB
Channel 1: LPDDR4, 50MHz
256B stride
lpddr4_set_rate: change freq to 400000000 mhz 0, 1
lpddr4_set_rate: change freq to 800000000 mhz 1, 0
Trying to boot from BOOTROM
Returning to boot ROM...
After Starting Kernel. Undecided
I am on my new Explorer now, running Bookworm on sd card.
( using cell data at the moment )
I really like it, but at the moment the Pro version of Bookworm is not
turning on the boot indicator light...
... IT DOES STILL BOOT....
... Just you are looking at a black screen and hoping it IS starting
Likely this will be fixed in the next update. ( hopefully )
JUST A HEADS UP
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(02-02-2022, 10:17 PM)bcnaz Wrote: I am  on my new Explorer now,  running Bookworm  on sd card.
JUST A HEADS UP
Still waiting for next Mobian weekly update.
I Guess lots of us are waiting, ===> impatiently i might add.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
I was about to burn a SD with Mobian. Thanks for your comments. I will wait
Sorry about that !
Mobian may be my fav,
but I would not suggest it at this moment in time,  ==> especially to try it for your first test drive.
It looks like the suspend is working now on the original Pine phone OS.
BUT NOW we just need it solved on the Pro series phone OS.
And the no boot light indicator...
====>  That CAN  all change with a single update.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 16 2,218 04-28-2024, 01:52 AM
Last Post: diederik
  Disable the GDM service in Mobian. mburns 0 483 11-25-2023, 10:19 PM
Last Post: mburns
  The Mobian Phosh Experience mburns 1 921 11-18-2023, 08:21 AM
Last Post: crocspot
  Fix the Mobian Weather App mburns 0 515 11-07-2023, 10:01 AM
Last Post: mburns
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 1 739 11-07-2023, 09:44 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 618 10-14-2023, 11:57 AM
Last Post: mburns
  Mobian libnotify custom notifications MadameMalady 5 1,451 08-01-2023, 08:51 AM
Last Post: MadameMalady
  Mobian .desktop file creation MadameMalady 15 3,309 07-27-2023, 04:12 PM
  XFCE mobian running nicely but some oddities grump_fiddle_reinstall 0 817 07-01-2023, 08:18 AM
  Manjaro Plasma unstable branch glitch mburns 2 1,100 06-21-2023, 08:03 AM
Last Post: mburns
