Hardware version identification?
Is there a simple way to do this?
My phone shipped 28/12/2021.
TIA
Jerry
The last PCB revision happened more than a year ago, since then it's v1.2b for all phones including the most recent Beta edition that you probably ordered.
(01-03-2022, 11:46 AM)kqlnut Wrote: The last PCB revision happened more than a year ago, since then it's v1.2b for all phones including the most recent Beta edition that you probably ordered.
Hello and thanks.
So I'd infer PCB check is the only way to find out? Would this be correct?
Are there any known hardware issues with the USB3 C-type connector? I can no longer find the reference.
MTIA.
Jerry.
(01-03-2022, 06:08 PM)g40 Wrote: So I'd infer PCB check is the only way to find out? Would this be correct?
Well the PCB it's the only thing that's different (apart from a sensor replacement at one point due to component shortages), so yeah ... Or do you mean ways of how to find out the revision? Apart from looking at the back cover (see if/which community edition it is), inspecting the PCB itself and testing for fixes I think there is no other certain way of finding out. As far as I know the hardware reports only the main version to the system (e.g. 1.2; you can find it in the dmesg output), but not the minor revision (e.g. 1.2b).
(01-03-2022, 06:08 PM)g40 Wrote: Are there any known hardware issues with the USB3 C-type connector? I can no longer find the reference.
With the connector itself und USB functionality no, not that I know of. You can find known issues behind the link I posted (click on the revision you want to know about). There may be issues with HDMI hot plug detection.
Very helpful, thank you.
  New Pinephone is dead. eMMC, boot, hardware issues. Shane 4 1,483 05-10-2023, 03:31 AM
Last Post: fxc
  UI crashes after unplugging USB device, seen on multiple OSes; is my hardware broken? slondr 1 975 11-05-2022, 11:31 AM
Last Post: slondr
Sad How many other users recieved a phone with FAULTY HARDWARE? johnnykeys 16 13,118 06-22-2022, 01:05 PM
Last Post: zer0sig
  Unhappy with immature Hardware jojuma 1 1,499 04-18-2022, 01:18 PM
Last Post: zetabeta
  Battery life: Maybe really a hardware issue? KNERD 34 21,882 09-23-2021, 01:11 PM
  Video playback with hardware acceleration jojuma 2 3,009 08-21-2021, 11:24 AM
Last Post: jojuma
  jumpdrive software might be faulty (or my pinephone hardware) zetabeta 3 3,316 07-20-2021, 03:14 PM
Last Post: zetabeta
  Kit version of the PinePhone? Redhatter 6 5,504 04-28-2021, 08:51 AM
  Does PINE64 ship to South America? Is v1.2b the final hardware? amosbatto 4 3,893 04-05-2021, 07:35 AM
Last Post: amosbatto
  Thoughts on 30 day hardware warranty? bartleby 10 8,637 03-04-2021, 02:39 PM
Last Post: TRS-80
