Browser cog - Problems on Mobian
Hello there,
the browser cog is a lightweight single window browser using WPE libraries. The problem is, that I cannot get the latest versions to run on Mobian - v0.8.1 is the last one functioning.
Has anyone here any ideas what could be the problem?
I tried the --platform= options, which result in errors that the libraries could not be found.
Thanks in advance!
Are you still on Bullseye (Debian Stable)?
A quick search of Debian packages shows that's the latest supported version in that release.
Cheers,
TRS-80
Protocols, not Platforms
(12-09-2021, 07:34 PM)TRS-80 Wrote: Are you still on Bullseye (Debian Stable)?
Thanks for your answer.
I'm on Bookworm and all the versions following 0.8.1 are not working.
I had the same issue and was dying without cog.  Building latest from source got it going again.
  1. uninstall existing cog version (sudo apt remove cog)
  2. checkout latest version from https://github.com/Igalia/cog (git clone "https://github.com/Igalia/cog.git")
  3. install dependencies (sudo apt install cmake build-essential pkg-config libcairomm-1.0-dev libwayland-client++0 libinput-dev libgbm-dev libdrm-dev libepoxy-dev libwayland-dev libwpewebkit-1.0-dev  libsoup2.4-dev  libgio3.0-cil-dev  libgio2.0-cil-dev  libwpebackend-fdo-1.0-dev )
  4. build and install:
  5. cd cog
  6. cmake .
  7. make
  8. make install
Did the trick for me, hope it helps!
  5. cd cog
  6. cmake .
  7. make
  8. make install
Thanks for the info! I will try that tomorrow.
Cog from Debian works again now Smile
I'm actually not using it anymore because I found Epiphany (GNOME Web) to be fast enough for most things and it has a nice way to create web apps from visiting a site.
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 26 2,631 Yesterday, 03:08 AM
Last Post: anonymous
  Mobian repository status henrythemouse 16 9,010 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 162 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,098 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,896 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 660 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,100 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,941 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 655 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 3,093 06-19-2023, 03:02 PM
Last Post: vusra
