[Support Request] Modem is Failing to Be Accessible
Bug
Phone does not report modem to end user making it inaccessible. Kill switch was toggled, tested on Arch Linux and Mobian, powered down and left overnight, and not sure what else to do from here. Any and all help would be greatly appreciated (and if there is a better place for this, please advise).
Output of sudo systemctl status ModemManager:
ModemManager.service - Modem Manager
    Loaded: loaded (/usr/lib/systemd/system/ModemManager.service; enabled; vendor preset: disabled)
    Active: active (running) since Sat 2021-11-27 22:45:08 CET; 2min 40s ago
  Main PID: 3098 (ModemManager)
      Tasks: 3 (limit: 3275)
    Memory: 8.9M
        CPU: 526ms
    CGroup: /system.slice/ModemManager.service
            └─3098 /usr/bin/ModemManager --test-quick-suspend-resume
Nov 27 22:45:07 arch systemd[1]: Starting Modem Manager...
Nov 27 22:45:08 arch ModemManager[3098]: <info>  ModemManager (version 1.18.4) starting in system bus...
Nov 27 22:45:08 arch systemd[1]: Started Modem Manager.
Nov 27 22:45:11 arch ModemManager[3098]: <info>  [base-manager] couldn't check support for device '/sys/devices/platform/soc/1c10000.mmc/mmc_host/mmc1/mmc1:0001/mmc1:0001:1': not supported by any plugin
I did more work on it and I believe that I have narrowed it down to a hardware issue. The modem has possibly been jostled loose from an impact. Manually maneuvering it appears to fix it and tapping the phone appears to cause the modem to drop. Not sure if the error message from ModemManager makes sense with this, but it seems to be fairly consistent when I manipulate it.
That doesn't sound promising - I don't imagine trying to reflow the modem would be easy. It might be worth trying the factory test OS which should have a basic hardware test.
https://wiki.pine64.org/wiki/PinePhone_S...ry_Test_OS
(11-29-2021, 02:59 PM)wibble Wrote: That doesn't sound promising - I don't imagine trying to reflow the modem would be easy. It might be worth trying the factory test OS which should have a basic hardware test.
I might test it later this week just to figure out more about the problem. I had another mobo so I just swapped them out.
Bug PinePhone modem keeps "disappearing" Kevin Kofler 21 23,978 09-11-2026, 09:18 AM
Last Post: idice
  Modem Issues with the Pinephone Temmie19 5 7,281 07-02-2025, 12:50 PM
  FOSS fw problem - PinePhonePro, EG25 modem dukla2000 5 7,073 02-05-2025, 02:30 AM
  Supported Carrier and Modem Bands NachoMomma 4 9,410 03-23-2024, 02:00 PM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 5,421 02-17-2024, 04:15 PM
Last Post: vortex
  modem not working michelinux 0 2,700 02-16-2023, 04:56 AM
Last Post: michelinux
  modem not detected al_x 3 9,383 02-15-2023, 11:17 AM
Last Post: fxc
  PinePhone carrier support in Hungary notramo 7 9,101 12-14-2022, 12:18 PM
Last Post: notramo
  firmware udate Quectel EG25-G modem alwi 7 16,142 07-06-2022, 01:43 PM
Last Post: user641
  Need command to tell what modem firmware I am on. purpletiger 4 8,599 07-06-2022, 12:35 PM
