Electron Bugs - Any Ideas? (Axolotl)
Hello there,
Axolotl is currently using Electron 15 as frontend and there are some bugs, which are a bit odd and I would like to ask, if anyone here has some experience with Electron and could provide some help.
1. Web links are opened in Axolotl instead of browser
https://github.com/nanu-c/axolotl/issues/538
2. Onscreen Keyboard not showing up
https://github.com/nanu-c/axolotl/issues/582
3. Input of certain letters not possible
https://github.com/nanu-c/axolotl/issues/635
From my point of view, all three bugs are connected to the Electron-Axolotl relationship, but my skills in this field are limited...
So it would be awesome, if some clues could be found.
Thanks in advance!
(11-19-2021, 03:05 AM)arno_nuehm Wrote: 1. Web links are opened in Axolotl instead of browser
I think this is probably a problem with the app itself and not Electron. It shouldn't be difficult to fix in the code: https://stackoverflow.com/questions/3174...in-browser.
(11-19-2021, 03:05 AM)arno_nuehm Wrote: 2. Onscreen Keyboard not showing up
Those might be caused by recent Electron bugs. I've never used Axolotl and I don't know how to update its Electron version. You can try building from source, maybe it will automatically download the latest version before compiling.
Thanks for your answers!
Regarding 2. and 3.: The latest Electron release (v16.0.0) causes a bug on Wayland systems, but I will test a fixed future version to see, if there are improvements.
1.: Thanks for that link. Maybe one of the ideas fixes the Axolotl bug.
(11-23-2021, 02:48 AM)arno_nuehm Wrote: Regarding 2. and 3.: The latest Electron release (v16.0.0) causes a bug on Wayland systems, but I will test a fixed future version to see, if there are improvements.
Have you tried latest 15.x?
Using 15.3.0 at the moment...
Looks like the Ozone Wayland backend is causing the letter bug - a user on github reported a similar thing using Chromium.
I tested Electron 15.3.0 without the backend and all the letters can be written...
  Axolotl on PinePhone / Mobian arno_nuehm 219 166,455 03-26-2023, 01:49 AM
Last Post: shulamy
  Mobian + phosh firefox ublock and other overlays display bugs tuxcall 3 1,813 02-24-2023, 12:11 AM
Last Post: nexion
  Axolotl not working? ragreenburg 11 6,790 08-31-2021, 09:34 AM
Last Post: Anna
  Axolotl on Pinephone CarmeloLabadie 1 2,215 07-26-2021, 12:56 AM
Last Post: kqlnut
  Axolotl on Mobian. What am I doing wrong? quixote 3 2,838 05-11-2021, 06:09 PM
Last Post: quixote
  axolotl. tor help rvh 5 4,466 05-02-2021, 11:03 AM
Last Post: rvh
  "Low Disk Space on Filesystem root" after installing Axolotl and Podcasts Anna 11 8,743 03-05-2021, 02:33 AM
Last Post: Anna
  Impressions and ideas herregaarden 4 4,872 10-07-2020, 12:04 AM
Last Post: LinAdmin2
