how to compile Linux from the SDK ?
There is a "BSP Linux SDK ver 4.19 for Quartz64 model A SBC"  here https://wiki.pine64.org/wiki/Quartz64#BSP_Linux_SDK
But it isn't obvious how to use it.
So I had a guess.  I want Linux for a Quartz64 model A.
First I run ./envsetup.sh and it asks me to pick a "combo" out of 0-91.
62. rockchip_rk3566
looks good to me. So I go for that.
Then I run ./build.sh
it asks me
You're building on Linux
Lunch menu...pick a combo:
0. default BoardConfig.mk
1. BoardConfig-rk3566-evb2-lp4x-v10.mk
2. BoardConfig-rk3568-evb1-ddr4-v10-spi-nor-64M.mk
3. BoardConfig-rk3568-evb1-ddr4-v10.mk
4. BoardConfig-rk3568-nvr-spi-nand.mk
5. BoardConfig-rk3568-nvr.mk
6. BoardConfig.mk
Which would you like? [0]:
Which one is a Quartz64 ?
Must be option 1 right? as it's the only option with RK3566
/usr/bin/ld: scripts/dtc/dtc-parser.tab.o:(.bss+0x10): multiple definition of `yylloc'; scripts/dtc/dtc-lexer.lex.o:(.bss+0x0): first defined here
collect2: error: ld returned 1 exit status
make[2]: *** [scripts/Makefile.host:108: scripts/dtc/dtc] Error 1
make[1]: *** [scripts/Makefile.build:425: scripts/dtc] Error 2
make: *** [Makefile:491: scripts] Error 2
ERROR: Running build_uboot failed!
ERROR: exit code 2 from line 341:
    ./make.sh $RK_UBOOT_DEFCONFIG ${RK_TRUST_INI_CONFIG:+../rkbin/RKTRUST/$RK_TRUST_INI_CONFIG} ${RK_SPL_INI_CONFIG:+../rkbin/RKBOOT/$RK_SPL_INI_CONFIG} ${RK_UBOOT_SIZE_CONFIG:+--sz-uboot $RK_UBOOT_SIZE_CONFIG} ${RK_TRUST_SIZE_CONFIG:+--sz-trust $RK_TRUST_SIZE_CONFIG}
Sad
The same patch that I suggest here for Android https://wiki.pine64.org/wiki/Android_SDK_for_RK3566 seems to help with Linux too
Is there any reason why you're picking the BSP Linux? Mainline kernels are pretty far with regards to support at the moment.
Even if you want to use BSP Linux, I recommend you just use the BSP kernel from https://gitlab.com/pine64-org/quartz-bsp...hip-linux/
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
I really thought it was going to finish compiling, but then:-
2021-11-17T19:32:41 Scanning dependencies of target pseudo_valgrind
2021-11-17T19:32:41 [ 91%] Building CXX object Tests/CMakeLib/PseudoMemcheck/CMakeFiles/pseudo_valgrind.dir/ret0.cxx.o
2021-11-17T19:32:41 /data.ssd/philip/rk3566/manjaro/sdk/new_rk3566_linux/buildroot/output/rockchip_rk3566/build/host-cmake-3.8.2/Source/cmServerProtocol.cxx: In member function 'std::size_t std::hash<LanguageData>::operator()(const LanguageData&) const':
2021-11-17T19:32:41 /data.ssd/philip/rk3566/manjaro/sdk/new_rk3566_linux/buildroot/output/rockchip_rk3566/build/host-cmake-3.8.2/Source/cmServerProtocol.cxx:620:43: error: 'numeric_limits' is not a member of 'std'
2021-11-17T19:32:41 620 |                          (i.second ? std::numeric_limits<size_t>::max() : 0));
2021-11-17T19:32:41 |                                           ^~~~~~~~~~~~~~
2021-11-17T19:32:41 /data.ssd/philip/rk3566/manjaro/sdk/new_rk3566_linux/buildroot/output/rockchip_rk3566/build/host-cmake-3.8.2/Source/cmServerProtocol.cxx:620:64: error: expected primary-expression before '>' token
2021-11-17T19:32:41 /data.ssd/philip/rk3566/manjaro/sdk/new_rk3566_linux/buildroot/output/rockchip_rk3566/build/host-cmake-3.8.2/Source/cmServerProtocol.cxx:620:67: error: '::max' has not been declared; did you mean 'std::max'?
2021-11-17T19:32:41 |        std::max
adding these two lines to buildroot/output/rockchip_rk3566/build/host-cmake-3.8.2/Source/cmServerProtocol.cxx seems to fix cmake:-
#include <stdexcept>
#include <limits>
(11-17-2021, 03:14 PM)CounterPillow Wrote: Is there any reason why you're picking the BSP Linux? Mainline kernels are pretty far with regards to support at the moment.
BSP isn't my motive.
I have been able to modify an Armbian image from another device to boot on the quartz, and there are mara's excellent SLARM64 images, and the official Mandrake images as well (but none with the older 4.19 kernel, so no HDMI output).
However there is nothing that I can find that I can compile myself from source. I want working, compilable source code.
If anyone can help me to compile something for myself then I would be really helpful.
The boards are supposed to be "open source", but if all that you can run on them are images that other people have compiled and you can't compile it yourself, then is it really open source?
(11-19-2021, 06:17 AM)dieselnutjob Wrote: However there is nothing that I can find that I can compile myself from source. I want working, compilable source code.
Then use upstream linux 5.16-rc1 and your own userland (buildroot or whatever?) instead of these jank rockchip bsp source dumps with awful tooling.
You can for example see what pgwipeout's CI does: https://gitlab.com/pgwipeout/quartz64_ci...lab-ci.yml
Plebian GNU/Linux
(11-19-2021, 08:33 AM)CounterPillow Wrote: You can for example see what pgwipeout's CI does: https://gitlab.com/pgwipeout/quartz64_ci...lab-ci.yml
would you mind explaining what that is please?
I don't think it's the kernel that's the problem. I am struggling to get u-boot to compile in Armbian. Once that works as you say it would be pretty easy to swap in any kernel that we like.
For u-boot, you'll currently have to use downstream u-boot with some quartz specific patches, which you can find here: https://gitlab.com/pine64-org/quartz-bsp...e/quartz64
The CI I linked shows you how pgwipeout builds his u-boot for example in "u-boot-job", the lines in the "script" section of the yaml file are the shell commands that are run.
Plebian GNU/Linux
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 8 18,866 03-07-2026, 04:21 PM
  SOQuartz Linux Builds stormwyrm 1 3,728 11-13-2023, 02:53 AM
Last Post: diederik
  Plebian Linux CounterPillow 8 12,652 07-19-2023, 08:51 AM
Last Post: CounterPillow
  Installing linux images emveepee 8 13,411 07-07-2022, 08:19 AM
Last Post: emveepee
  Mainline linux Mwo87 4 8,932 07-06-2022, 05:38 AM
  Debian Userland on top of existing Linux build? dieselnutjob 3 6,976 01-25-2022, 01:12 PM
Last Post: dieselnutjob
  Boot Linux on microSD card? dieselnutjob 2 6,460 10-01-2021, 05:15 PM
