Boot Linux on microSD card?
Is there any image which I can put on a microSD card which will boot Linux on the Quartz64?
Yes, you have two choices.
For both, you will require a UART adapter. There is no video output.
The pgwipeout image is what I use at the moment. Installing Debian may require you to manually set up your root partition in the installer (it did for me, but maybe I did something weird).
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
(09-27-2021, 01:12 PM)CounterPillow Wrote: Yes, you have two choices.
thanks.
I just tried the Manjaro image and it seems to work well.
Yes I needed a woodpecker adapter.  These instructions worked https://forum.pine64.org/showthread.php?tid=5029
Once the config scripts had completed it seemed to enable sshd by default so I can ssh in without the woodpecker
I found that I can leave the eMMC with Android plugged in.
If the sdcard is there then it boots Manjaro from the sdcard, and if it isn't then it boots Android from the eMMC
thanks again.
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 8 17,697 03-07-2026, 04:21 PM
  SOQuartz Linux Builds stormwyrm 1 3,299 11-13-2023, 02:53 AM
Last Post: diederik
  Plebian Linux CounterPillow 8 11,396 07-19-2023, 08:51 AM
Last Post: CounterPillow
  SOQuartz Blade PXE Boot NCLI 1 3,176 05-05-2023, 09:49 AM
  Installing linux images emveepee 8 12,387 07-07-2022, 08:19 AM
Last Post: emveepee
  Mainline linux Mwo87 4 8,241 07-06-2022, 05:38 AM
  Debian Userland on top of existing Linux build? dieselnutjob 3 6,499 01-25-2022, 01:12 PM
Last Post: dieselnutjob
  how to compile Linux from the SDK ? dieselnutjob 7 12,487 11-19-2021, 03:34 PM
