Audio / Touchscreen - 2 New Stupid Questions
If I attach the touchscreen - - - it sounds like I have a wide connector for the video itself, and a narrow ribbon for the touch controls...so...
1) Are these ribbons of sufficient length to work with the acrylic enclosure, or should I abandon that bit?  It's fine if not, as I think I'd have a clunky look just laying the screen on the acrylic enclosure.
1b) Are there / Can I use some kind of short (under 12") EXTENSION CABLES for either/both of these ribbons?
but more importantly...
2) Does the touchscreen have SPEAKERS that work with Android...if so I'm assuming that this is carried by the wide ribbon connector?  If I install the touchscreen Android build, will I have audio through the screen, or do I need to do some other connecting?
2b) Is there something I have to do in SOFTWARE to get audio to work (drivers, etc.)?
Thanks,
(06-26-2016, 09:06 AM)phloog Wrote: If I attach the touchscreen - - - it sounds like I have a wide connector for the video itself, and a narrow ribbon for the touch controls...so...
Thanks,
1. We try to optimize the cable length for EMI purpose. You can adjust the LCD cable lenght due to their is an adapter in middle.
2. Speaker connector located at Euler bus.
3. This depends on your application, driver, and OS.
  Hello All! New user - 2 basic Quartz64 questions oldschool 2 938 12-14-2023, 12:06 AM
Last Post: oldschool
  Pre-purchase questions (and an apology/plead) mayorchief 0 2,282 08-23-2020, 11:30 PM
Last Post: mayorchief
  Pre-boot questions bkheath 5 8,341 04-30-2019, 08:33 AM
Last Post: bkheath
  Motherboard PCI-E questions Debbie 1 3,416 03-31-2019, 06:26 PM
Last Post: mknawabi
  questions SammiLeighTully 2 4,469 11-20-2018, 02:17 PM
Last Post: SammiLeighTully
  Multi Room Audio - Pine style mjgoode 4 8,696 09-19-2018, 10:30 AM
Last Post: mjgoode
Question Do I need a touchscreen to run Android? chrbar 3 5,156 08-08-2018, 10:55 PM
Last Post: chrbar
  Which command line only OS? For streaming audio zirconx 5 6,317 09-27-2016, 06:53 AM
Last Post: zirconx
  A little whinge Some simple questions I hope MobileFusion 3 5,977 09-22-2016, 07:29 AM
Last Post: MobileFusion
  Audio quality ctigs 3 5,744 08-13-2016, 10:58 PM
Last Post: MarkHaysHarris777
