A little whinge Some simple questions I hope
I have tried asking these questions direct to Pine with no reply. Come on guys you have a good product but a product is only as good as the support.
Anyway whinge over and now the questions...
1. I am going to buy a LCD screen in the next few weeks, but want to know is there is any operating system which would allow me to run dual screen one HDMI connected to the port and also the lcd?
2. Is there any list of PI hats that will work o the pine if not any tutorials and what would be needed?
3. When will the be (as promised) European distributer(must say the shipping is improving things are taking a little over a week)?
I can partially address #1 & #2 - and hopefully TLLim will spot this and comment on #3.
With regards to #1, it does look like the pine64 display configuration supports a dualhead mode, meaning you will be able to run both the LCD and HDMI at the same time... but other than that... I have no idea how you get it to work. These posts by tkaiser might give you some ideas on how it is configured, and what you can do with the pine64 display settings.
For #2, there is no list at the moment, as the documentation is still in a shocking state, or non-existent at times. However, there are two known issues with the Pine64s RPi headers as far as I'm aware. Pin 7 is currently programmed for driving the backlight of the LCD display, so isn't readily available without some changes in code and recompiling stuff, etc. And the I2C bus has the pullup resistors missing, so you will either need to add pull up resistors to the pine64, or to your RPi hat if it doesn't have any.
(09-22-2016, 02:59 AM)MobileFusion Wrote: 1. I am going to buy a LCD screen in the next few weeks, but want to know is there is any operating system which would allow me to run dual screen one HDMI connected to the port and also the lcd?
The basic support for this is available in all Allwinner tablet SoCs (the A series A64 is part of) since day one. Back in those days you configured the display settings in proprietary fex files, now in so called device tree files. Principles are the same. Adding to the link above just two more links:
The second one should give the idea that basic support is easy, getting a combination to work in a reasonable manner is another thing. A reseller of A20 equipment promised me last year to send a 1024x600 dpi LCD for review (never arrived) and I ordered one with HDMI with the same resolution (which caused some hassles due to being a non-standard resolution) to provide a dual display tutorial. Never happened and unfortunately LeMaker's CEO/CTO from the 2nd link above never got back to me. Fortuntely (for me) I almost all the time use Allwinner devices headless anyway.
That being said I would assume that those guys currently bringing Android 7.0 to Pine64 will come up first with working settings (they're doing an amazing job).
Talking about that 1024x600 HDMI display reminds me of some Armbian users reporting getting non-standard HDMI resolutions working flawlessly by tweaking fex files and use the fb0_width/fb0_height parameters on H3 boards. Since HDMI driver in BSP kernel for H3 and A64 is pretty similar that would be worth a try here too. Did a quick search, maybe it was this thread: http://forum.armbian.com/index.php/topic...3-devices/
At least there you find a link to the patches we applied to H3 HDMI driver to provide additional real resolutions. Talked to longsleep about that in March or April and suggested to provide an a64disp utility comparable to the h3disp we wrote for H3 devices back then. IIRC he wanted to adjust display resolution only through settings in uEnvt.txt and refrained from adding additional resolutions. But it should be easy to add the few more native resolutions Armbian added for H3 to BSP kernel sources for A64 also (maybe someone wants to poke ayufan -- I don't think longsleep changed much of his mind regarding display output, he's using Pine64 headless as most if not all linux-sunxi devs).
With H3 it looks currently like this regarding available HDMI resolutions (all it needs is a dev looking in Armbian's github repo and add the stuff the longsleep's kernel):
root@orangepione:~# /usr/local/bin/h3disp
Usage: h3disp [-h/-H] -m [video mode] [-d] [-c [0-2]]
 This is a tool to set the display resolution of your Orange
 Pi by patching script.bin.
 In case you use an HDMI-to-DVI converter please use the -d switch.
 The resolution can be set using the -m switch. The following resolutions
 are currently supported:
    480i use "-m 480i" or "-m 0"
    576i use "-m 576i" or "-m 1"
    480p use "-m 480p" or "-m 2"
    576p use "-m 576p" or "-m 3"
    720p50 use "-m 720p50" or "-m 4"
    720p60 use "-m 720p60" or "-m 5"
    1080i50 use "-m 1080i50" or "-m 6"
    1080i60 use "-m 1080i60" or "-m 7"
    1080p24 use "-m 1080p24" or "-m 8"
    1080p50 use "-m 1080p50" or "-m 9"
    1080p60 use "-m 1080p60" or "-m 10"
    1080p25 use "-m 1080p25" or "-m 11"
    1080p30 use "-m 1080p30" or "-m 12"
    1080p24_3d use "-m 1080p24_3d" or "-m 13"
    720p50_3d use "-m 720p50_3d" or "-m 14"
    720p60_3d use "-m 720p60_3d" or "-m 15"
    1080p24_3d use "-m 1080p24_3d" or "-m 23"
    720p50_3d use "-m 720p50_3d" or "-m 24"
    720p60_3d use "-m 720p60_3d" or "-m 25"
    1080p25 use "-m 1080p25" or "-m 26"
    1080p30 use "-m 1080p30" or "-m 27"
    4kp30 use "-m 4kp30" or "-m 28"
    4kp25 use "-m 4kp25" or "-m 29"
    800x480 use "-m 800x480" or "-m 31"
    1024x768 use "-m 1024x768" or "-m 32"
    1280x1024 use "-m 1280x1024" or "-m 33"
    1360x768 use "-m 1360x768" or "-m 34"
    1440x900 use "-m 1440x900" or "-m 35"
    1680x1050 use "-m 1680x1050" or "-m 36"
 Two examples:
    'h3disp -m 1080p60 -d' (1920x1080@60Hz DVI)
    'h3disp -m 720i' (1280x720@30Hz HDMI)
 You can also specify the colour-range for your HDMI-display with the -c switch.
 The following values for -c are currently supported:
    0 -- RGB range 16-255 (Default, use "-c 0")
    1 -- RGB range 0-255 (Full range, use "-c 1")
    2 -- RGB range 16-235 (Limited video, "-c 2")
Thanks for the info guys that's really useful
  Hello All! New user - 2 basic Quartz64 questions oldschool 2 774 12-14-2023, 12:06 AM
Last Post: oldschool
  Pre-purchase questions (and an apology/plead) mayorchief 0 2,225 08-23-2020, 11:30 PM
Last Post: mayorchief
  PINE64 Installer - Simple Way to Image Your MicroSD pineadmin 101 149,199 01-15-2020, 12:46 PM
  Pre-boot questions bkheath 5 8,163 04-30-2019, 08:33 AM
Last Post: bkheath
  Motherboard PCI-E questions Debbie 1 3,345 03-31-2019, 06:26 PM
Last Post: mknawabi
  questions SammiLeighTully 2 4,380 11-20-2018, 02:17 PM
Last Post: SammiLeighTully
  Audio / Touchscreen - 2 New Stupid Questions phloog 1 3,630 06-26-2016, 07:17 PM
  Newbie Questions akool64 4 7,287 06-05-2016, 02:30 PM
Last Post: Ghost
  A few questions SERIOUS ANSWERS ONLY yourhighpriestess 6 8,613 04-19-2016, 02:32 PM
Last Post: marshmel
  Simple questions from a non tech guy. Ramlatus 6 11,865 02-07-2016, 11:03 AM
Last Post: dermo529
