[Solved] My phone won't boot with SD card inserted
Sad
I just got my pinephone yesterday and was very excited to test different distros. The phone can boot from SD card without any issue, but I found that after I flashed the image to eMMC and partitioned my SD card again hoping to use it as storage, my phone just won't boot Sad
The SD card is SandDisk Extreme 128GB SDXC that I bought the same day I received the phone, and I'm sure it's genuine.
The screen lights up after holding power button but it won't even show things like red led that implies something went wrong, it just straight out won't boot.
I've already tried the dd command from
Quote:Reuse SD card for data storage on system booting from eMMC
in the official guide, and I've checked with gparted that all of the spaces of my SD card is formatted as fat32. (I've also tried NTFS)
The phone will boot into the OS I flashed into eMMC if I pull out the SD card.
Any suggestions will be appreciated!
Are you sure you did everything right here:
https://wiki.pine64.org/wiki/PinePhone_I..._from_eMMC
(11-06-2021, 01:54 PM)acrux Wrote: https://wiki.pine64.org/wiki/PinePhone_I..._from_eMMC
Thanks for the reply, but I mentioned I did that already in my post Smile
(11-06-2021, 01:54 PM)acrux Wrote: Are you sure you did everything right here:
+1
(you still have boot bits at the front of the SDcard that have to be cleared.)
My bad, found out that I need to use the dd command on /dev/sdb (The SD card) instead of /dev/sdb1 (the fat32 partition I created).
I thought accessing /dev/sdb and /dev/sdb1 will be the same if I create a partition using all the free spaces, but apparently I'm horribly wrong.....
  Pinephone boot. Richy_T 8 7,790 10-21-2025, 12:12 PM
Last Post: Richy_T
  Default password for KDE plasma pine phone Toni 0 8,252 09-14-2025, 06:35 PM
Last Post: Toni
  US Mobile, via T-Mobile, won't support Pinephone Pro - SOLVED, SIMPLY jovval 14 23,270 07-18-2025, 04:24 PM
Last Post: dchang0
  My new phone stopped working. gunnygee 3 4,555 12-12-2024, 01:21 PM
  Pine Phone in Australaa and Telstra tracyanne 2 3,088 12-06-2024, 02:42 AM
Last Post: tracyanne
  Can't complete update of manjaro: wwan0 stays disabled; no phone/text gilford 3 4,073 12-05-2024, 06:42 AM
Last Post: gilford
  How boot Alpine Linux realroot 4 4,854 11-02-2024, 01:00 PM
Last Post: linmob
  2G, 3G still is in phone. Piotr Bujakowski 5 6,349 09-19-2024, 03:49 AM
Last Post: jennybaso
  Tow boot MTXP 5 6,874 08-22-2024, 03:11 AM
Last Post: Pavlos1
  Pinephone won't boot. spha 13 15,566 05-15-2024, 10:31 PM
Last Post: Richy_T
