Does GPS work on a separate chip or is GPS built into the LTE modem?
Hi.
Pinephone.
(11-02-2021, 09:58 AM)Mikoduso Wrote: Hi.
Pinephone.
in the LTE modem module.
(11-02-2021, 06:03 PM)tllim Wrote: in the LTE modem module.
Thx.
Is Quectel firmware proprietary? Open firmware for Quectel modems does not exist?
Yes. It exists. Look the Boktorgs firmware on github.
To clarify on the firmware a bit, the phone arrives with Quectel's proprietary firmware installed because that's required for regulatory approval. The open firmware replaces the supervisory part of the modem firmware, but still uses the Qualcomm binary firmware for the radio layer.
https://github.com/Biktorgj/pinephone_modem_sdk
(11-08-2021, 03:08 AM)wibble Wrote: but still uses the Qualcomm binary firmware for the radio layer
Thanks.
Is it possible to replace the radio firmware?
Pinephone.
Why was it decided to use the GNSS module as part of the LTE modem, and not separately?
Indeed, if the radio modem has a backdoor for remote connection and control, then the functionality of the GNSS module can be disrupted and the coordinates will not be correct.
Thanks.
In theory a sufficiently well skilled, resourced and motivated team might be able to do it. In practice I'm not aware of anyone having done so - the skill and resource barriers are pretty high. The closest I'm aware of is OpenBTS.
Pinephone.
Many (most?) LTE modems now have GNSS built in. Using a separate GNSS module means extra cost, board space and power usage. For most people that's a poor trade as their threat model just isn't that extreme. You still wouldn't know whether that GNSS module's firmware had a backdoor via one of its RF interfaces, so you might instead insist on a software defined radio implementation. Even that doesn't help when someone starts messing with the GNSS signals, as is apparently not uncommon in some parts of the world.
(11-22-2021, 05:30 AM)wibble Wrote: In theory a sufficiently well skilled, resourced and motivated team might be able to do it. In practice I'm not aware of anyone having done so - the skill and resource barriers are pretty high. The closest I'm aware of is OpenBTS.
I assume that all radio medems have a 100% backdoor programmed for special services
(11-22-2021, 05:30 AM)wibble Wrote: You still wouldn't know whether that GNSS module's firmware had a backdoor via one of its RF interfaces
Intelligence agencies constantly abuse the control of phones and smartphones through the radio module
  Supported Carrier and Modem Bands NachoMomma 4 1,616 03-23-2024, 02:00 PM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 559 02-17-2024, 04:15 PM
Last Post: vortex
Bug PinePhone modem keeps "disappearing" Kevin Kofler 14 5,685 03-22-2023, 05:28 PM
  modem not working michelinux 0 935 02-16-2023, 04:56 AM
Last Post: michelinux
  modem not detected al_x 3 4,247 02-15-2023, 11:17 AM
Last Post: fxc
  firmware udate Quectel EG25-G modem alwi 7 5,443 07-06-2022, 01:43 PM
Last Post: user641
  Need command to tell what modem firmware I am on. purpletiger 4 2,899 07-06-2022, 12:35 PM
  The modem does not recognize Korean SIM cards (what?) bdicewk 9 4,157 06-13-2022, 04:12 AM
Last Post: zetabeta
  Modem Hardware bad? Not ready for 5g?? linux76 8 4,767 05-31-2022, 06:41 PM
Last Post: SwordfishII
  Modem in failed state, not sending/receiving SMS brb78 5 3,694 03-31-2022, 08:37 AM
Last Post: wibble
