Audio
Hi, if i do
cat /proc/asound/cards
0 [sndhdmi        ]: sndhdmi - sndhdmi
                     sndhdmi
i don't get jack device. Can someone help me?
Hi, you need to load the module for the sound-codec and get the config file for alsamixer, see discussion here:
http://forum.pine64.org/showthread.php?tid=807
Thank you for your reply but i can not make it work. If i follow the guide in the first post i get new element whit aplay -l but i can't get it working anyway. In what i'm wrong?
It´s required to use SU for some of the commands, not sudo. Maybe that´s the problem.
No i'm trying to make it working on dietpi that by default use su
Music Getting analog audio/sound to work (headphones socket) on debian pfeerick 7 26,037 12-30-2016, 07:37 AM
Last Post: Birneklub9
  Audio not detected babolivier 10 16,633 09-03-2016, 10:40 AM
Last Post: jwouellette
