What is "Music" and why does it have root access?
Question
I just opened up the Usage app (not something I've used before) and noticed that an app called Music has root access. Music has a speaker cup icon beside it and uses 3MB of storage space. It doesn't come up if I search apps.
What is "Music" and why does it need root access?
TIA  Big Grin
For byte-sized tech and software tips check out my Danimations Digital Media tips channel on Youtube Big Grin
That's the Anbox container manager, Usage just doesn't know how to display it properly so it uses one of the desktop files autogenerated by Anbox its for Android apps. You can run "sudo systemctl stop anbox-container-manager" and see the Music "app" in Usage disappear. It's nothing to worry about Wink
  Music stops playing when screen goes off and session gets suspended jojuma 2 2,341 10-24-2021, 03:04 AM
Last Post: jojuma
  Pandora music streaming client jtn0514 0 1,120 09-27-2021, 07:51 PM
Last Post: jtn0514
  minicom to access quectel modem Rainer 3 3,507 05-20-2021, 05:44 AM
Last Post: wibble
