Pandora music streaming client
So, just wanted to share a little solution i ran into for streaming music via pandora. I was toying with Beta 15 just recently and made an attempt to get pithos (pandora streaming client) working. Seems like it works out of the box pretty much. The UI leaves a bit to be desired in terms of control (no real thumbs up/down or like) but its better than nothing!
Enable SSH on your phone (systemctl start sshd) and run the following commands as the manjaro user:
mkdir ~/src && cd ~/src
sudo pacman -S git base-devel
git clone https://aur.archlinux.org/pithos.git
https://github.com/pithos/pithos.git
cd pithos
makepkg -si
On the main apps menu, hit the 3 lines on thetop right and uncheck "Show only adaptive apps" and you should see a white icon with a blue note titled "pithos".
You will probably have to change the display scaling a bit to get the app to show right, however you'll probably do that anyway when setting up the phone.
  Axolotl signal client package lolgzs 27 19,753 11-02-2022, 04:55 AM
Last Post: shulamy
  Plasma mobile email client Athansor 9 9,426 11-18-2021, 02:00 AM
Last Post: ryo
Question What is "Music" and why does it have root access? danimations 1 1,611 11-03-2021, 04:37 AM
Last Post: marcih
  Music stops playing when screen goes off and session gets suspended jojuma 2 2,341 10-24-2021, 03:04 AM
Last Post: jojuma
  xmpp&jabber client for Manjaro Plasma mobile acrux 15 11,560 09-13-2021, 10:02 PM
Last Post: TRS-80
