PinePhone connects to Wi-Fi then disconnects (Initial setup)
PinePhone64 Community Edition will not connect to home Wi-Fi (Asus AX11000) @2.4GHz
Using Distro. “Manjaro-ARM-plasma-mobile-pinephone – 20210423.img.xz”
The following (below) is what is reported by my AX11000 when trying to setup PinePhone64
For reporting below the MAC ADDRESS has been removed and substituted with: [MAC Address Removed] My Router connects for a brief few seconds and then disconnects. No problems exist for other Wi-Fi connections. How can I correct the PinePhone64 from disconnecting? This is what my AX11000 System Log reports:
Auth, [MAC Address Removed] status: Successful (0), rssi:0
Oct 8 09:50:39 wlceventd: wlceventd_proc_event(556): wl0.2: Assoc [MAC Address Removed], status: Successful (0), rssi:0
Oct 8 09:50:39 wlceventd: wlceventd_proc_event(491): wl0.2: Deauth_ind [MAC Address Removed], status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
The problem is that after entering the password the phone connect and then disconnects using Wi-Fi. I have not been able to get to trying to set up the phone for cell service since I can't get past the Wi-Fi setup connection. Help appreciated....
  my pinephone melted norayr 6 801 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 1,073 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  various tricks to open the pinephone shengchieh 2 692 03-23-2024, 09:27 AM
Last Post: Ferriah
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 323 03-21-2024, 08:52 AM
Last Post: unrznbl
  pinephone keyboard + dock question tuxcall 7 2,769 02-05-2024, 03:17 PM
Last Post: wigan
  Unsatisfactory GPS reception on PinePhone? LinAdmin2 53 55,610 12-17-2023, 11:42 AM
Last Post: robin.com.au
  PinePhone Pro not booting (Cap error!, pctl timeout) jealda 2 1,374 11-16-2023, 05:03 AM
Last Post: DrYak
  Pinephone frame damages Uturn 2 962 10-23-2023, 02:49 AM
Last Post: Uturn
  Replacement screen disconnects after back frame is screwed on robthebold 4 1,337 10-12-2023, 01:03 PM
Last Post: robthebold
  PinePhone Keyboard KJ6OHG 11 8,064 08-23-2023, 03:25 AM
Last Post: Kali
