Booted Phosh 16 Beta once and now won't boot
I downloaded the Phosh 16 Beta yesterday and played around with it for a bit then when I went to boot it up this morning it would vibrate, show the notification light turn on then go black. I left it for about 10 minutes to see if maybe it was booting up but the screen was just dim and nothing happened. I tried booting into it 4-5 times with the same result. Anyone else experiencing this?
(10-07-2021, 08:57 AM)ragreenburg Wrote: I downloaded the Phosh 16 Beta yesterday and played around with it for a bit then when I went to boot it up this morning it would vibrate, show the notification light turn on then go black. I left it for about 10 minutes to see if maybe it was booting up but the screen was just dim and nothing happened. I tried booting into it 4-5 times with the same result. Anyone else experiencing this?
sounds very similiar what i had with pre-installed k plasma.
my guess is something installed updates on a background and it got messed up, maybe package "linux-pinephone" or "linux-firmware" or else.
take a look at this https://forum.pine64.org/showthread.php?tid=14978 . i re-installed "linux-pinephone" and manage to get back (though removed it for beta phosh later).
Interesting, thanks.
I had same issue with pacman -Syu update yesterday. After extensive installs by pacmen, system was reporting that 1 files did not download properly. Did not write down name. I went to try pacman again and it wouldn't run pacman. Then it unbooted. Upon rebooting got no login after many tries.
Had to do new install with download of latest revision. After install, pacman -Syu reinstalled 400+ files. But all looks to be working now.
I think I will offload my telephone contacts before each pacman update as I never know when a reinstall might be needed.
  Boot fails ionmich 6 1,263 11-02-2023, 05:14 AM
Last Post: Uturn
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 810 04-25-2023, 09:49 AM
Last Post: jakfish
  Backup and Home Screen Tinkering on Phosh jakfish 0 863 02-24-2023, 12:56 PM
Last Post: jakfish
  Manjaro plasma-mobile Beta 13 Uturn 13 4,915 01-25-2023, 04:15 PM
  MMS workaround for users with separate APN (works atleast on Manjaro Phosh) alaraajavamma 0 1,073 10-10-2022, 12:53 PM
Last Post: alaraajavamma
Question Running AnBox on Manjaro ARM w/ Phosh? danimations 2 2,507 09-05-2022, 03:42 PM
Last Post: nroth
Question Help installing Snaps on Pinephone running Manjaro ARM w/ Phosh danimations 2 1,897 04-07-2022, 06:02 AM
Last Post: danimations
  Manjaro Plasma Beta and Cellular Data Service Fred Zyphal 7 5,116 03-17-2022, 05:50 PM
Last Post: Fred Zyphal
  Manjaro Phosh Issues Csanderson0313 7 5,938 03-05-2022, 08:23 AM
Last Post: Csanderson0313
  No wifi with phosh image wave22 3 2,454 02-15-2022, 07:25 AM
Last Post: wave22
