Installing Manjaro on EMMC
I've been trying unsuccessfully to flash to eMMC the images from https://github.com/manjaro-arm/quartz64-...s/releases
In absence of any instruction, I thought that a simple dd would have been enough, but it does not look so.
Flashing the image the the SD card works well though! Is there something different to flash the image, or something more to do afterward?
The symptoms are that during the boot sequence, it just stops always at the same place, just after kernel start:
Starting kernel ... [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [    0.000000] Linux verGCC) 10.2.0, GNU ld (GNU Binutils) 2.35) #1 SMP PREEMPT Fri Sep 17 12:52:46 UTC 2021 [    0.000ne64 RK3566 Quartz64-A Board [    0.000000] earlycon: uart8250 000] printk: bootconsole [uart8250] enabled [    3.048209] rockchip-usb2phy fe8a0000.usb2-phy: failed to cre[    3.067859] arm-scmi firmware:scmi: Failed. SCMI protocol 2e [    3.496594] arm-scmi firmware:scmi: Failed. SCMI protocol 19 not active. [    3.499908] arm-scmi firmware:scmi: Failed. SCMI protocol 17 [    3.561017] rockchip-dw-pcie 3c0000000.pcie: invalid resour) Starting version 249.4-1-arch
and then never goes farther...
  Installing Arch Linux ARM on the Quartz64 CounterPillow 4 10,192 05-30-2022, 06:22 PM
Last Post: CounterPillow
