How to remove "Show Only Adaptive Apps" option in arch-phosh
I have multiple apps functioning as satisfactorily or more so than all of the default apps on my arch-phosh pinephone. These apps that the system seems to think it's not compatible with only appear when the widget in the top-right corner is checked, plus it defaults to only showing the 'adaptive apps' when restarted.
I would like to at least set it's default to not hiding most what I use the phone for, but my main goal is to completely remove the widget to possibly replace it with something of use.
looks like there's an issue filed about this very gripe (which i share on manjaro phosh) https://source.puri.sm/Librem5/phosh/-/issues/579
Off:
gsettings set sm.puri.phosh app-filter-mode '[]'
On:
gsettings set sm.puri.phosh app-filter-mode '["adaptive"]'
  PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup mikehenson 3 10,075 01-09-2025, 05:02 AM
  LibreOffice usable with Arch Linux on the Pinephone? Peter Gamma 2 4,065 07-28-2024, 05:12 AM
Last Post: Peter Gamma
  stuck between phosh and plasma aular 0 2,451 02-27-2024, 05:55 PM
Last Post: aular
  Updating Arch Linux _radv_ 8 9,429 02-20-2024, 09:35 AM
Last Post: _radv_
  How to install arch with FDE user641 3 5,813 01-11-2024, 10:18 PM
  How to find software app, on Arch Phosh? general_lee 5 8,948 10-15-2023, 10:12 PM
  Arch auto mount usb example Lazy_one 2 9,261 10-06-2023, 09:36 AM
Last Post: luppivega
  Remove modem firmware aular 10 11,818 08-23-2023, 05:53 PM
Last Post: aular
  Arch with FDE user641 1 3,914 07-29-2023, 08:27 AM
Last Post: alpineduck
  No keyboard on Arch Plasma when entering password on document Chief 0 3,308 12-03-2022, 08:35 PM
Last Post: Chief
