Big thanks to Armbian!
I still love my Pinebook. It doesn't get as much love as it should since it's slower than my phone, but I've been trying various different operating systems out again to see what I think. However since the Pinebook Pro came out, this model has been treated as legacy. Quite sad since it's still up for sale, but there you go.
I've tried and got the following:
  • KDE Neon - Nice enough, but all of a sudden stopped updating and working for me. Was support dropped?
  • Manjaro - Not for me. Works well enough but I'm not a fan of Arch (personal preference) and I found it to be slower than Neon.
  • Q4OS - Omg, they have an XP theme that's super close! My leading choice at this point and really easy and comfortable to use.
And then I tried Armbian Hirsuite... I love my Pinebook all over again!
Hisuite is based on 21.04, so is surprisingly bleeding-edge for a laptop branch others consider legacy. But powered with XFCE4, it suddenly feels super speedy like it did when it first came out!
To give a familiar look and feel refresh, I installed the Chicago95 theme. The theme dev has worked really hard on this and it definitely shows as it feels like I'm running some kind of Plus! pack on Windows 95!
The only thing I've come across so far is the sound doesn't work? But at this rate I'm usng the Pinebook for productivity not entertainment purposes. It also boots via a UEFI solution so I think it also suffers from the Manjaro charging issue too sadly, so I'm planning on installng aufan ubuntu to the emmc if that becomes a problem (charging while using seems to work well).
Now don't get me wrong, you open an Electron app or Chromium and you can see the system visibly slow down, however I was able to run Visual Studio Code at a bearably slow speed! Impressive considering how chonky of an app VS Code is. And I mean with lots of extensions (I write PHP, Python and Java).
So a big thanks to the Armbian devs for keeping up support for this fantastic little cheap laptop. You guys really made me fall in love with it all over again.
[Image: NcbesgV.png]
[ PHP Developer | Pinebook 1G | About me ]
Thumbs Up
Yes, I just booted Armbian Hirsute on my Pinebook and it runs very well.
I hadn't used the Pinebook in some time and I was looking for a newer OS to run over the Ubuntu 14 that came with the Pinebook.  Armbian Hirsute (Ubuntu 21) seams to fit that bill.
As noted on the Armbian website, suspend doesn't work.
I need to research how to load Armbian to the eMMC.
Thanks for pointing out that new Armbian was there for the pinebook, I hadn't looked for a while |-)
Now sitting on the couch, pinebook on my lap since long time Smile
rookieone@pinebook-a64
OS: Armbian hirsute (21.08.6) aarch64
Host: Pinebook
Kernel: 5.15.4-sunxi64
Uptime: 56 mins
Packages: 1601 (dpkg)
Shell: bash 5.1.4
Resolution: 1366x768
DE: Xfce 4.16
Theme: Numix Daily [GTK2/3]
Icons: Numix [GTK2], Adwaita [GTK3]
Terminal: x-terminal-emul
CPU: sun50iw1p1 (4) @ 1.152GHz
Memory: 821MiB / 1957MiB
Yay! Smile
And thank you Armbian of course!
BTW, the audio from the speakers seems to work just fine (after cranking up the volume via alsamixer), but to me it looks like the 3.5mm jack not working for sound, need to check again..
  Change console resolution (Armbian/bookworm) jcgraybill 1 978 06-22-2023, 01:31 PM
Last Post: jcgraybill
  Armbian 22.02 Release Announcement TRS-80 0 1,348 02-28-2022, 05:02 PM
Last Post: TRS-80
  Armbian - Xenial Desktop (Pinebook) pineadmin 83 111,038 07-17-2019, 01:22 PM
Last Post: catsmile
  Wi-fi stops working - Armbian cel 1 3,139 06-26-2019, 01:57 PM
Last Post: cel
  Failure in setting the display backlight with Armbian 5.86 [SOLVED] wlad 0 2,007 06-11-2019, 03:36 AM
Last Post: wlad
Exclamation Armbian - need help, locked out myself by setting backlight to zero UltraBloxX 6 7,424 03-31-2019, 12:36 PM
Last Post: guidol
  Armbian 18.04 (Bionic) for Pinebook Luke 0 3,256 08-17-2018, 02:28 PM
Last Post: Luke
