09-27-2021, 01:03 AM
Is there any image which I can put on a microSD card which will boot Linux on the Quartz64?
Boot Linux on microSD card?
09-27-2021, 01:12 PM
Yes, you have two choices.
For both, you will require a UART adapter. There is no video output. The pgwipeout image is what I use at the moment. Installing Debian may require you to manually set up your root partition in the installer (it did for me, but maybe I did something weird). Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64 Open Hardware Quartz64 Model A TOSLink Adapter Pi-bus GPIO Extender For ROCKPro64 And Quartz64
10-01-2021, 05:15 PM
(09-27-2021, 01:12 PM)CounterPillow Wrote: Yes, you have two choices. thanks. I just tried the Manjaro image and it seems to work well. Yes I needed a woodpecker adapter. These instructions worked https://forum.pine64.org/showthread.php?tid=5029 Once the config scripts had completed it seemed to enable sshd by default so I can ssh in without the woodpecker I found that I can leave the eMMC with Android plugged in. If the sdcard is there then it boots Manjaro from the sdcard, and if it isn't then it boots Android from the eMMC thanks again. |
Debian Userland on top of existing Linux build? | dieselnutjob | 3 | 803 |
01-25-2022, 01:12 PM Last Post: dieselnutjob |
how to compile Linux from the SDK ? | dieselnutjob | 7 | 1,979 |
11-19-2021, 03:34 PM Last Post: CounterPillow |
