PineTab Early Adopter Edition
Is there any work being done to make the PineTab early adopter edition usable? I haven't seen an OS update to be installed since I took delivery of the device.
The current state of the machine doesn't allow me to use it as an every day machine to do any work.
What are you after? I am making slow progress in the background on top of Danct12's Arch kernel - I would suggest it is relatively mature. You can then install some window manager on top and get a pretty nice experience for a 'laptop'-like device (if you have the keyboard) and a touchscreen.
(09-24-2021, 10:46 AM)khbehrens Wrote: Is there any work being done to make the PineTab early adopter edition usable? I haven't seen an OS update to be installed since I took delivery of the device.
You can try other OSes via an sd card,  Mobian has both the stable "Bullseye" and the testing Bookworm Nightly releases.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(09-24-2021, 04:33 PM)barray Wrote: What are you after? I am making slow progress in the background on top of Danct12's Arch kernel - I would suggest it is relatively mature. You can then install some window manager on top and get a pretty nice experience for a 'laptop'-like device (if you have the keyboard) and a touchscreen.
I want to use the tablet while on the road. I use LibreOffice for custom data bases I have created to run my business. I need to connect with my mail & web server while traveling. I want to be able to install and use software that I have on my Ubuntu 20.04 machines. Since I can do none of these things on the PineTab, it is useless in its current state. It seems to me that I should be able to boot a Ubuntu 20.04 install flash drive and install the OS to the internal SSD just like I do with any other hardware without flashing a SD card to try different OS's.
The option to use the sd card, is just that, "an option"
It can be handy for trying or testing other operating systems. and it is pretty quick and painless.
Like running your desktop or laptop from a 'live' disk, when you take out the media, your original OS is untouched.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
  PineTab-V Experiences segaloco 0 623 09-29-2026, 11:28 PM
Last Post: segaloco
  Pinetab-V boot rescue anoduck 2 1,949 10-21-2025, 12:58 AM
Last Post: anoduck
  Any updates on Bluetooth for PineTab 2? BluetoothBroke 1 2,512 08-05-2025, 06:38 AM
  Bricked Pinetab 2 vatin 6 5,673 06-06-2025, 08:46 AM
Last Post: maxaltepo
  Gentoo on Pinetab istewart 0 2,279 01-26-2025, 08:21 PM
Last Post: istewart
  Pinetab-V Upgrade WrVLink 0 2,450 12-14-2024, 02:30 AM
Last Post: WrVLink
  PineTab Bluetooth PimpDiCaprio 5 6,866 11-02-2024, 11:46 AM
  Pinetab 2 just arrived + when can hope to se wifi driver LRP 15 23,759 02-28-2024, 05:03 AM
Last Post: Surehand53
Wink Screen protector for PineTab 2 vatin 0 3,022 11-18-2023, 01:31 AM
Last Post: vatin
  PineTab 2 (arm64) thoughts and questions acruhl 7 10,975 09-01-2023, 01:13 PM
Last Post: acruhl
