No HDMI output on monitor but HDMI works on TV
Got my rockpro64 last week, but I cannot make it work with my Philips monitor HDMI. Power up the board with Manjaro ARM and monitor doesn't detect a signal and goes to sleep mode.   Absolutely nothing is displayed like there might be a hardware issue.
(Monitor works fine with my desktop or laptop on HDMI (1.4) no problem. I have tried switching a few cables, no luck).
However rockpro64 works perfectly fine if i plug it into my TV's HDMI input, boots up nicely and displays the login and desktop..
Any ideas how I can get it to work on my monitor? Is it some sort of firmware issue?  Thanks in advance.
hi,
could it be a power issue ?
Things you can test :
- plug the hdmi after the boot
- try hdmi to dvi if you have such input and cable
- try another distribution (armbian for example)
- disconnect all devices from screen and board before boot
best luck.
LMM
  HDMI missing, SPI fail & continuos reboots Jack_A 0 2,817 07-26-2026, 11:34 AM
Last Post: Jack_A
  (real) Mainline U-boot finally works on SPI, boots SATA, throw away your SD cards NOW aleksei 0 13,005 06-21-2025, 06:21 AM
Last Post: aleksei
  No HDMI Video - Anything To Check? angrymallard 2 4,772 09-29-2024, 06:54 PM
  Serial Output Garbage after initial messages jamforlunch 5 10,936 09-07-2024, 03:32 PM
Last Post: foresto
  HDMI Degraded and now Bad Quality jamforlunch 0 4,111 02-13-2023, 08:51 PM
Last Post: jamforlunch
  Dual Monitor Setup cmodernel004 3 10,322 03-08-2021, 06:02 PM
Last Post: Mangled
  External monitor through usb-c Mangled 0 3,119 03-06-2021, 11:21 PM
Last Post: Mangled
  there no hdmi out on OMV chengjianwen 0 3,505 03-21-2019, 09:00 AM
Last Post: chengjianwen
