there no hdmi out on OMV
I installed OMV, and there is no HDMI output always.
and every it crashed(I think) and can't boot again, I must install the fresh OMV again, and again.
I installed autoshutdown plugin, and the system seems never shutdown by it.
I configure the interface to WoL enabled, but I can't wake it up use a perl/python script.
the only worked component is ats, the fan worked well.
the two hard 4G disks /dev/sda and /dev/sdb always disappeared when boot the system from a long downtime.
I want to known if I shoud change to debian + samba, to let problems simply.
BTW, I use a 16GB eMMC to boot the system, and installed flash memory plugin, too.
  HDMI Degraded and now Bad Quality jamforlunch 0 834 02-13-2023, 08:51 PM
Last Post: jamforlunch
  No HDMI output on monitor but HDMI works on TV archamin 1 2,060 09-15-2021, 10:46 AM
Last Post: LMM
