New PinePhone user
Hello all,
I thought I should share my experience with getting a PinePhone, since I lurked here for a long while before joining, trying to get all of the information I could, before I spent my hard earned cash on a Beta phone; I was a bit worried things would not work in my country.
I’m coming from ios, but didn’t need all of the things there and just wanted a basic phone that did not spy on me.
I ordered my PinePhone on August 31st & got it today, September 7th (in the EU). The company did great, very fast order processing & handling, complete with DHL online tracking, which was spot on.
I followed the Wiki and got the phone up & working right out of the box. Calls work both ways and missed calls show a notification popup message from my telco (Telenor). I’m really looking forward to testing out this device.
Great Job on the phone to all at Pine & thank you for your work, I’ve wanted a functional Linux phone for more than 20 years. Smile
Satisfied PinePhone, Pinebook Pro & PineTab2 owner; Thank you Pine64Team for your work!  Smile
Which operating system are you using?
(09-12-2021, 06:35 PM)unrealb2 Wrote: Which operating system are you using?
Just as shipped, Manjaro with Plasma.
I want to keep it as stock as possible for 30 days of testing, only applying updates.
7 days as a daily driver so far, incoming messaging is fast/instant, while outgoing messages seem to lag 20-60 minutes (I have to pay per message, so I don’t really send any), calls work fine & the apps are sufficient for me. Data works, but I don’t use the web much on my phone, have a tablet and laptop with free net.
I really think a lot of the connection issues depend upon your cellular provider. I’m in Eastern Europe with Telenor and they support a lot of products.
I’ve ran into a few software problems, but nothing I couldn’t fix with the information online.
I’m happy to report that my perfectly fine iphone is back in it’s box.  Smile
The Pine phone can run any operating system from a micro sd card with No Effect on the system that is installed on the
"Factory installed eMMC operating system".
I recommend testing using just a 8 or 16gb sd card, these are cheap, they can be used repeatedly, and if you need to zero wipe
your sd card....  it takes much less time to zero wipe a smaller sd card.
Some forum members have reported it 'can be hard to record over the Manjaro operating system', SO..
  Say you want to try flashing Arch to your sd card after trying Manjaro,
it may not work just recording over the Manjaro image,  but MAY require a zero wipe first.
Most of the time, just flashing without a zero wipe DOES work,  but ...  sometimes it is necessary to do a zero wipe first.
AGAIN :  testing operating systems running from an sd card, will Not effect your system that is installed to your eMMC,
  ............  simply remove the sd card and your phone will again run from the operating system installed to the eMMC.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
Thanks for the heads up and I have to admit, I did not last the 30 day trial time I set for myself with the stock system.
(I was just happy to be able to do my daily tasks on Linux phone.)
I put Mobian with Phosh on a sd to try today after work and the difference is night and day.
  PinePhone - boot from microSD laserpyramid 7 596 04-25-2024, 05:56 AM
Last Post: aular
  pinephone virtual keyboard aular 4 363 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 243 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 109,330 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,809 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 613 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,377 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 504 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,713 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,988 12-04-2023, 02:14 AM
Last Post: Peter Gamma
