Pinephone won't let me enter password
I updated my Pinephone tonight and when it restarted, I cannot enter the passphrase to boot the phone. It's like the keyboard doesn't work. This is the Mobian version.
Anybody know how to help me?
Thanks!
You did not mention if you are running from the eMMC or an sd card.?
The simplest GUI fix would be to just put on a whole fresh new install.
       "This is the Mobian version"    ?
   Mobian phone,  or  Mobian operating system,  or both.?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(09-01-2021, 12:50 AM)bcnaz Wrote: You did not mention if you are running from the eMMC or an sd card.?
Sorry for the missed info.
I am running from the phone, no sd card. This is the Mobian community edition, and I haven't changed anything.
Thank you.
Thank you.
There are multiple ways to 'fix' your phone. depending on your Linux experience.
My suggestion would be a fresh install of the nightly release.
 Simply download from the Mobian site, then use the jump drive method
to install it to your phone. If you do not want to run from an sd card.
 Pretty good instructions on doing that in the forum and the wiki.
I prefer running from the sd card as I change fairly often.
On my daily driver I change about every 3 to 6 weeks with updates inbetween.... My extra test phones I sometimes change daily.
  The latest Mobian release has reduced the power usage a lot.
Sent from a Manjaro Convergent phone running Mobian nightly release from September 1st on an sd card... using Pure Talk for my mobile data connection.
Good Luck !
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
Thank you.
Good Luck !
Thank you! I got it running again.
I have this problem periodically when I am too impatient to open the phone, especially after rebooting. If I wait until modem comes up (see bars) and the little ^ at bottom starts to wiggle, before swiping up, I never have a problem! Coincidence? Witchcraft? Not sure. Smile
Cheers,
TRS-80
Protocols, not Platforms
  PinePhone - boot from microSD laserpyramid 9 755 8 hours ago
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 387 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 261 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 110,304 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,895 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 644 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,468 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 524 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,766 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 7,055 12-04-2023, 02:14 AM
Last Post: Peter Gamma
