Paste button does not work
So I'm using a pineohone, with the pre-installed OS (Manjaro, I'm pretty sure). Right now I'm trying to set up Tootle, so I can use my mastodon account. Trouble is, I cannot get the paste button to work to enter the confirmation code. I can reliably bring up the prompt, by entering some text, highlighting it, and then tapping on it - but when I tap the paste button, nothing happens. I'm not sure if this is an issue with Tootlde, or Manjaro - I thiiink KDE plasma might be at fault? Not sure though. Anyway, is this a bug, or is there a setting I need to change somewhere, or is pasting just not as simple as tapping a button when I have something saved to keyboard...?
I also cannot drag the cursor around text fields - it has that hanging indicator below, but when I try and tap and drag that to move the cursor, it does not work. This makes using text fields much, much harder.
I'm also having issues with the keyboard not disappearing when I tap outside a text field, making it really hard if not impossible to use some apps - in this case, I'm really struggling with kmail.
  How to paste text in Plasma Mobile? jojuma 5 3,940 11-13-2021, 11:04 AM
Last Post: acrux
  Won't Work Unless Plugged In romulus 1 2,062 08-18-2021, 12:47 AM
Last Post: acrux
  LTE doesn't work (Ukraine) moondance4n 18 13,498 06-23-2021, 05:06 AM
Last Post: mouffa
  "short codes" no longer work on the spacebar texting app? mudflap 0 1,246 05-31-2021, 08:26 AM
Last Post: mudflap
  Does siglo not work in manjaro plasma? Athansor 0 1,530 05-03-2021, 01:06 PM
Last Post: Athansor
  Outgoing calls/sms work, incoming don't user12345 2 3,093 04-12-2021, 10:11 AM
Last Post: user12345
  Anbox starts and kinda work on Lomiri Manjaro now paju1986 0 1,695 01-15-2021, 03:37 PM
Last Post: paju1986
Shocked Possible reason why MANY applications dont work properly in Manjaro on the PinePhone kern707 4 5,336 12-04-2020, 09:46 AM
Last Post: kern707
  After todays upgrade unlock screen does not work anymore LinAdmin2 14 12,989 11-13-2020, 07:54 AM
Last Post: LinAdmin2
