Won't Work Unless Plugged In
My pinephone gets stuck in a sort of loop of having me enter my password, then the screen flashes a few times and kicks me back to the lockscreen. It only does this while not receiving power. If it is plugged in and getting power everything works fine. If it is plugged in while I am using it then I unplug it, it turns off. The battery percentage also moves around quite a bit. It changes by a few percent more right when I unplug, then shows over 10 percent more when unplugged and on lockscreen. It is completely up to date as of today, running Manjaro with KDE Plasma.
Any and all help is appreciated
Angel
(08-17-2021, 03:49 PM)romulus Wrote: My pinephone gets stuck in a sort of loop of having me enter my password, then the screen flashes a few times and kicks me back to the lockscreen. It only does this while not receiving power. If it is plugged in and getting power everything works fine. If it is plugged in while I am using it then I unplug it, it turns off. The battery percentage also moves around quite a bit. It changes by a few percent more right when I unplug, then shows over 10 percent more when unplugged and on lockscreen. It is completely up to date as of today, running Manjaro with KDE Plasma.
Angel
Can't confirm here.
At some stage of development, the Setup->Screen application wrote incorrect values to /.config/powermanagementprofilesrc file. There are several posts with solutions here so do a search Wink
Or flash a fresh image - that bug has been fixed.
  Paste button does not work Angle 0 1,103 08-24-2021, 12:02 PM
Last Post: Angle
  LTE doesn't work (Ukraine) moondance4n 18 13,547 06-23-2021, 05:06 AM
Last Post: mouffa
  "short codes" no longer work on the spacebar texting app? mudflap 0 1,247 05-31-2021, 08:26 AM
Last Post: mudflap
  Does siglo not work in manjaro plasma? Athansor 0 1,536 05-03-2021, 01:06 PM
Last Post: Athansor
  Outgoing calls/sms work, incoming don't user12345 2 3,096 04-12-2021, 10:11 AM
Last Post: user12345
  Anbox starts and kinda work on Lomiri Manjaro now paju1986 0 1,696 01-15-2021, 03:37 PM
Last Post: paju1986
Shocked Possible reason why MANY applications dont work properly in Manjaro on the PinePhone kern707 4 5,341 12-04-2020, 09:46 AM
Last Post: kern707
  After todays upgrade unlock screen does not work anymore LinAdmin2 14 13,019 11-13-2020, 07:54 AM
Last Post: LinAdmin2
