Fan doesn't spin
I bought 2 pin fan and connected it to the fan header on the RockPro64 board. Installed OMV on the MMC, it boots up fine but the fan doesn't spin. Did I buy a broken fan/board or do I need to flick a switch somewhere?
(08-04-2021, 08:34 AM)captainmorgan Wrote: I bought 2 pin fan and connected it to the fan header on the RockPro64 board. Installed OMV on the MMC, it boots up fine but the fan doesn't spin. Did I buy a broken fan/board or do I need to flick a switch somewhere?
You need ATS software to control the fan.
https://forum.pine64.org/showthread.php?tid=6489
It seems the problem is with the OMV image. I've now installed Armbian and the fan started spinning immediately, no additional software was required.
  ROCKPro64 sometimes doesn't Power On Pete Tandy 2 6,516 08-24-2021, 05:50 AM
Last Post: Pete Tandy
