KDE password
Hi All,
I changed my password to something containing letters and numbers on my pinephone community KDE.
But the login screen only has numbers.
How do I change it from my PC over USB?
Hi, if you have ssh enabled, then just ssh in and change the password.
if not, if you can plug in a USB keyboard, then you can try switching to a tty ( ctrl + alt + <F1..F6> ). From there you can log in and change your password.
Alternatively, you could boot to another OS and chroot from there. If the OS that you've locked yourself out of is on the eMMC, then boot from an SD card, then mount the necessary partitions from the eMMC and chroot into it, then change the password.
Hope that helps
  Lost password on second hand Ubports PinePhone? Peter Gamma 6 3,435 04-10-2022, 01:20 PM
Last Post: Peter Gamma
  Pinephone won't let me enter password czgunner 5 4,301 09-07-2021, 08:50 PM
Last Post: TRS-80
  What is the first-time password? Chupacabra 10 12,453 03-29-2021, 09:43 AM
Last Post: Puro Antinori
  PinePhone Pin/password question dgdimick 3 4,067 03-28-2021, 06:32 PM
Last Post: dgdimick
  I am stuck, When in Terminal, unable to enter a password Whio84 3 2,987 02-12-2021, 03:46 PM
Last Post: Whio84
  Default Password for New Pine64 KDE Plasma CE? robertb1 3 5,258 02-01-2021, 04:29 PM
Last Post: cybercricket
  default password for Manjaro pinephone Raniyah 1 3,576 11-23-2020, 11:50 PM
Last Post: kqlnut
  First Time Password 123456 does not work (SOLVED) OggieDoggie 0 1,730 11-06-2020, 09:14 PM
Last Post: OggieDoggie
