Manjaro KDE dolphin not showing usb device
Hi, I can see usb device in the manage disks utility, but I can't access the device through dolphin. I can manually mount & access through console.
Has anyone had this problem? Any suggestions appreciated. Thanks, straightwalker
SOLVED
more or less. The Disks utility recognizes a hot plugged usb and allows mounting and/or unmounting and offers options that can be edited.
If the drive is in when the PBP is booted, the Disk utility will mount it in /ROOT/mnt/usbname. If the drive is put in after the boot, the Disk utility mounts it in /ROOT/media/usrname/usbname (or maybe it has a "/run" in that path, I don't remember). In any case, Disks lists the path to the mounted usb drive, and you can access the contents using Dolphin (by beginning the path with ROOT).
There is probably a way to automate this, or make it less manual, but I couldn't figure it out. At least, you can access any drive you put in. If you are using the same usb drive each time (and you get the settings right), the process is automatic. It seems that you have to set up options for each new drive that you use.
I'm sure others can explain better ways. But it does work, even though an added device never appears on the Dolphin sidebar.
  Converting the Pinebook Pro into a CrowView Note like device 8jef 0 1,971 08-18-2024, 05:42 PM
Last Post: 8jef
  Manjaro versions bad and good gilwood 0 2,922 02-12-2024, 05:03 PM
Last Post: gilwood
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 11,728 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 5,387 12-13-2023, 08:17 PM
Last Post: trillobite
  Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native) astr0baby 201 502,471 05-12-2023, 06:09 AM
Last Post: korreckj328
  Manjaro Plasma blinking cursor jcun4128 4 5,970 05-08-2023, 11:17 AM
  PBP blank screen after updating Manjaro Franko 6 8,356 04-01-2023, 07:55 AM
Last Post: hacknix
  Manjaro - which libdrm? hacknix 0 2,364 04-01-2023, 03:21 AM
Last Post: hacknix
  Partial boot after installing Manjaro on emmc regivanx 11 12,590 02-06-2023, 09:11 AM
  Manjaro pinebookpro images with kernel 5.7.19 rfm83 11 14,854 01-22-2023, 10:05 PM
Last Post: rfm83
