Struggling to get USB-C DP to work
Hello
i am using Lenovo ThinkPad 40A9 dock for my daily driver Lenovo E595. I thought to test it with pinebook, but result was mixed, as i've described here.
Today i've returned to seek for rootcause, and what i came with, was this message
Jul 21 02:21:04 pinebook kernel: cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
when dock was plugged.
I've started to connecting dots: firmware was present in /usr/lib/firmware, but yet somehow it was invisible for rockchipdrm module. After some tinkering, i've modified a file
[root@pinebook etc]# sdiff -s mkinitcpio.conf mkinitcpio.conf_20210730
FILES=(/usr/lib/firmware/rockchip/dptx.bin)       | FILES=()
regenerated my initrd and verified that file is actually included before rootfs gets mounted, so exactly when it's needed.
After reboot, somewhat success - no errors about missing firmware ,yet no image after connecting to dock, despite both plugs orientations
kernel says
[  26.816477] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
Is there anything else that i can do/ mess with/ try? i really am into docking Pinebook to my existing dock, as i have already nicely set up my desk and buying another "maybye compatible one" is missing my point.
my kernel: 5.13.4-1-MANJARO-ARM, vanilla from repo (yet i don't see a problem to recompile if needed, Gentoo fan here ;d)
There are several things related to external displays on a Pinebook Pro;
  • Must be USB C alternate mode Display Port
  • If the laptop dock is USB C alternate mode HDMI, it will never work
  • Some laptop docks use USB Display Link, which is basically a USB attached video card. These require drivers on the Pinebook Pro and maybe slower.
Checking your device it "appears to be using USB C alternate mode Display Port". Notice to quotes. It appears to be. That's part of the problem, manufactures not being crystal clear in their specifications.
So, try several other OSes and see if they work with your laptop dock. If so, then it's a software problem. Not "USB C alternate mode HDMI", which will never work with the Pinebook Pro.
Arwen Evenstar
Princess of Rivendale
  Getting the dock to work. wove 2 4,110 12-27-2020, 09:27 AM
Last Post: wove
  Can't get wired headset microphone to work mjc 1 2,847 10-16-2020, 07:08 AM
Last Post: Arwen
  Still struggling with microphone input diodelass 0 2,103 06-15-2020, 05:49 PM
Last Post: diodelass
Question Is work still being done on the Pinebook Pro keyboard drivers User 11436 5 6,855 06-12-2020, 10:10 AM
Last Post: Arwen
  Backlights doesn't work Bloris 7 10,215 11-06-2019, 06:59 AM
Last Post: WilFree
  You guys think this screen combination would work on the pinebook or no? BeauS 3 5,524 08-10-2019, 06:18 AM
Last Post: User 12559
