You guys think this screen combination would work on the pinebook or no?
I know the device uses usb c to a cables, that should work shouldn't it?
https://www.kickstarter.com/projects/747...=user_menu
(07-26-2019, 10:51 PM)BeauS Wrote: I know the device uses usb c to a cables, that should work shouldn't it?
I'm skeptical I'm afraid. It looks like the hardware is a usb based graphics card directly connected to a display. That's similar hardware to USB based docking stations and IIRC the devices that do that tend to have proprietary closed source x86-only drivers.
I could be wrong though so no harm in asking them...
You could also make the 2nd screen yourself.
Take a look at this "DIY perks"-video:
https://www.youtube.com/watch?v=CfirQC99xPc
The Kickstarter thing costs almost as much as a PBP.
So the value for money is not great...
Marketing for this thing is BS... Says Plug & Play, but drivers are required (which is not „Plug & Play“ by definition). Generally, I would stay away from all USB-Type-A monitors. There might not even be any Linux drivers, and certainly none for ARM. If possible, try to always use one for either USB-Type-C (driverless over DP alternate) or one specifically meant for a display port like Displayport or HDMI.
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 2 379 04-09-2024, 04:33 AM
Last Post: maxjrh
  Pinebook Pro on Debian 12 Power Issue u974615 1 302 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 243 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 579 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,032 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 128,958 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 5,906 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,300 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 133,917 11-30-2022, 04:28 PM
  Decent Pinebook Pro barrel PSU / Charger petaramesh 3 1,852 10-21-2022, 07:57 AM
Last Post: dachalife
