Pinephone not logging me in even though I have the right pin
Bug
Ok so I just setup my pinephone and i setup the pin code  (keep in mind I do remember it) so when it finished setting up it told me to login with my pin ofc so I did but it says that it's incorrect even though I put it in right and I remember it. I did this multiple times and nothing worked. How do I fix this ?
numbers only or letters?
  PinePhone Pro and PinePhone Community Edition Different SIM Card Trays dorkydev 2 221 04-11-2024, 03:10 PM
  Where PinePhone Pro are Made Tony90 1 525 01-18-2024, 09:20 AM
  using Zoom on Pinephone andrew907 5 1,181 12-09-2023, 01:26 AM
Last Post: crocspot
  pinephone 3 ideas aular 2 792 11-30-2023, 07:57 AM
Last Post: aular
  Does pinephone allow you to repair your own device as easily as fairphone? unix21311 3 1,978 11-06-2022, 10:37 PM
Last Post: Harolddavies0
  can i install mobian on pinephone? luofeiyu 2 1,318 10-15-2022, 07:31 AM
Last Post: user641
  Does the pinephone have hardware kill switches located on the outside of the phone? unix21311 2 1,802 10-03-2022, 05:53 AM
Last Post: unix21311
Sad New PinePhone Mobian Weekly Image... No Boot photon 1 1,161 09-27-2022, 07:00 AM
Last Post: olyavi
  used PinePhone Mobian CE or PineTab CelynRollins 1 1,645 01-11-2022, 06:31 AM
Last Post: collierreinhold
  Are you OK with the size of the PinePhone? guenther 14 8,428 12-16-2021, 12:12 AM
Last Post: zetabeta
