Does pinephone allow you to repair your own device as easily as fairphone?
Hey guys,
I was wondering if the pinephone allows you to repair your own phone as easily as fairphone?
https://www.fairphone.com/en/
Does pinephone have like this modular approach where if for example your camera is broken you can easily replace the camera with a replacement part yourself without needing a technician?
(10-02-2022, 10:09 PM)unix21311 Wrote: Hey guys,
i think it is yes and no. pinephone is quite easy to open and it doesn't use weird screw. but it's not that modular, some components are replaceable, but mainboard practically have to be replaced as one.
https://pine64.com/product-category/pine...are-parts/ . camera modules seems to be available, but shipping fees might be annoying. pinephone regular and pp pro components are not compatible to each other.
I see mate, thanks mate Smile
But one thing, would pinephone consider making it as modular as fairphone in the next update, can I request for this?
Ithink it is yes and no
  PinePhone Pro and PinePhone Community Edition Different SIM Card Trays dorkydev 2 147 04-11-2024, 03:10 PM
  Where PinePhone Pro are Made Tony90 1 458 01-18-2024, 09:20 AM
  using Zoom on Pinephone andrew907 5 1,109 12-09-2023, 01:26 AM
Last Post: crocspot
  pinephone 3 ideas aular 2 742 11-30-2023, 07:57 AM
Last Post: aular
  can i install mobian on pinephone? luofeiyu 2 1,277 10-15-2022, 07:31 AM
Last Post: user641
  Does the pinephone have hardware kill switches located on the outside of the phone? unix21311 2 1,726 10-03-2022, 05:53 AM
Last Post: unix21311
Sad New PinePhone Mobian Weekly Image... No Boot photon 1 1,125 09-27-2022, 07:00 AM
Last Post: olyavi
  used PinePhone Mobian CE or PineTab CelynRollins 1 1,606 01-11-2022, 06:31 AM
Last Post: collierreinhold
  Are you OK with the size of the PinePhone? guenther 14 8,287 12-16-2021, 12:12 AM
Last Post: zetabeta
  I SHOULD NOT HAVE PURCHASED THE PINEPHONE Scooterman 5 4,533 12-09-2021, 06:52 AM
Last Post: ryo
