Problems with Twinkle SIP Application, strerror_r is not available
Sad
I am having trouble with the Twinkle SIP application.
I am able to use Zoiper on my laptop, but Zoiper won't run in PinePhone. (If I am wrong, please send me a link so I can install.)
For the Zoiper app, I use the following information:
username (123456)
password (135790)
and the SIP server sip.companyname.abc
I put these in Twinkle and when I try to connect, I get an error:
Failed to create a UDP socket (SIP) on port 5060
strerror_r is not available: 98
I am also not sure where I should be putting the information I have into Twinkle in order to log in correctly. Twinkle has many, many options and I did my best, but it just won't seem to connect.
Does anyone know what to do?
  Auto start application on Phosh login Zebulon Walton 8 3,407 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  Stability problems with 6.1 kernel Zebulon Walton 9 2,615 05-12-2023, 08:09 AM
Last Post: zetabeta
  DNS Problems with Mobile Data arno_nuehm 29 17,046 10-29-2022, 09:16 AM
Last Post: treebeard
  Problems after Tow-Boot Dinosaur1946 3 1,765 09-18-2022, 12:48 AM
Last Post: SpaggettiCoder
  Will this battery-saving script cause problems? rp3 1 1,231 08-28-2022, 02:00 PM
  Tow-boot problems and restoring uboot Zebulon Walton 15 7,710 08-14-2022, 11:09 AM
Last Post: shulamy
  Browser cog - Problems on Mobian arno_nuehm 5 3,934 02-10-2022, 03:27 PM
Last Post: pothos
  ARM Microsoft Teams-problems installing eaglebeckley 15 14,391 01-14-2022, 01:59 AM
Last Post: Tazdevl
  rsyslog a bad idea? Problems with ssh, openssh-server, fail2ban Anna 7 5,267 11-14-2021, 06:20 PM
Last Post: juju
  How Do I Perform a Chatty Application Reinstall? rrholmes 2 2,405 07-13-2021, 01:11 AM
Last Post: rrholmes
