How Do I Perform a Chatty Application Reinstall?
I made a mistake and deleted my Chats (Chatty) application.  Somehow, in the process, I manageed to get the O/S to say that the application is installed but now the icon is missing.  Not sure exactly what I did wrong now.  The Mobian O/S states that the application was last updated on June 26, 2021.  Can someone point me in the right direction on this issue???  Thanks in advance!
I did:
$ dpkg-query -l *chat*
...and it looks like the package is actually called `chatty` after all.
Have you tried doing (in terminal):
$ sudo apt install chatty
Cheers,
TRS-80
Protocols, not Platforms
That did solve the problem! Thanks for your assistance TRS-80.
  Chatty Matrix Decryption Key jojuma 2 281 02-26-2024, 12:48 PM
  Jabber with chatty user641 2 986 11-12-2023, 02:10 AM
Last Post: user641
  Auto start application on Phosh login Zebulon Walton 8 3,407 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  Chatty does not work after suspend mode user641 4 1,948 07-18-2023, 10:43 AM
  beware chatty 0.7.0~rc0-1 treebeard 6 2,622 11-06-2022, 04:51 PM
Last Post: treebeard
  Dist-upgrade and Chatty vs Gnome-Contacts biketool 9 4,076 09-30-2022, 08:53 PM
  Unable to send messages with chatty user641 0 778 09-07-2022, 04:35 AM
Last Post: user641
  Chatty - XMPP receiving photos - inline display doesn't work arkadione 2 1,988 07-10-2022, 03:16 AM
Last Post: arkadione
Sad Chatty can no longer start since the last update anonymous 10 5,396 06-08-2022, 01:03 PM
Last Post: Korac
  Backing up SMS and phonebook before wipe/reinstall biketool 2 1,452 05-09-2022, 09:20 PM
